Adjust Chain on Sidestand, or With Rear Wheel in the Air? - Ducati.ms - The Ultimate Ducati Forum
post #1 of 6 (permalink) Old Sep 20th, 2017, 11:40 am Thread Starter
2016 Scrambler Flat Track Pro.
I'm confused, do I adjust the chain with the bike on the side stand (and the rear wheel touching the ground), or with the rear wheel raised and spinning freely?
Thanks
DrSpencer is offline
post #2 of 6 (permalink) Old Sep 20th, 2017, 11:48 am
Are you aligning the chain or adjusting the slack?
Aligning the chain..
wheel need to be off the ground.
Adjusting the slack...
Can do either on the ground or off the ground. But off the ground will be easier to adjust.
mak620 is offline
post #3 of 6 (permalink) Old Sep 20th, 2017, 12:02 pm Thread Starter
wheel on the ground.
Bike is getting its 600 miles service.
I will be cleaning, lubing, and adjusting the chain.
I clean/lube with the rear wheel in the air.
Do I adjust the chain slack with the rear wheel in the air or on the ground?
Thanks
post #4 of 6 (permalink) Old Sep 20th, 2017, 3:49 pm
DukeDesmo's Avatar
Images: 197
I always adjust chains on a paddock stand. On both my Ducatis it makes no real difference whether on the bikes sidestand or paddock stand, the slack is about the same but even if it were different then, just measure the difference from one to the other and adjust it a little more or less accordingly so that it is correct on the ground.
I leave them on the loose side anyway so 5mm or so either way doesn't make much difference anyway...
916, M900 & Guzzi LeMans II
DukeDesmo is offline
post #5 of 6 (permalink) Old Sep 20th, 2017, 7:39 pm
Images: 4
If you adjust the slack with the wheel in the air, it might be wise to walk the bike for one complete chain revolution while watching for tightness, just in case it makes a difference. After you do this once , you'll know whether you have to bother.
duc96cr is offline
post #6 of 6 (permalink) Old Sep 24th, 2017, 6:49 pm
if you're using the ducati spec on the swingarm sticker then do it how they say, which i assume would be sidestand. otherwise, sit on the bike and feel the freeplay when it is loaded. scrambler chains do tighten quite a bit when loaded.
Brad The Bike Boy
www.bikeboy.org
bradblack is offline
Air Filters - Stock vs Aftermarket, and Airbox Resonance JEC Hall of Wisdom 12 Jun 12th, 2018 1:52 am
The story of a rear wheel.. spikey1973 Sport Touring 6 Jun 10th, 2017 5:21 am
Help Removing Rear Wheel Bill A Multistrada 27 Mar 13th, 2017 8:10 pm
Setting air gap on rear wheel ABS sensor davisjj Multistrada 1 Jul 25th, 2016 8:10 pm
Rear wheel scratched at tyre shop oxygem steve Supersport 5 Jun 4th, 2016 5:06 am
