Valves and Belts - Ducati.ms - The Ultimate Ducati Forum
  • 1 Post By greer
post #1 of 5 (permalink) Old Jul 8th, 2016, 8:17 am Thread Starter
Valves and Belts
I'm just home from a 4,200 mile trip, and past due on the valve and belt check. We've always done our own maintenance (BMW's, Triumph's, all manner of Jap bikes, HD Sportster, MG Jackal) and hope to give this a whirl. If I understand correctly, this is a detuned Monster 796 engine. Is there a particular how-to write up or video you all might recommend? I appreciate any advice and suggestions. Thanks
Sarah
2015 Ducati Scrambler Full Throttle
greer is offline
post #2 of 5 (permalink) Old Jul 11th, 2016, 11:41 am
Stick's Avatar
here's one place to look at:
Ducati 900SS Tune and service info
I'm sure there are others...
Stick -~~~- Need an adrenaline rush? Shove a DUC between your legs.
Present DUCs: 2013 MTS1200S GT, 2003 ST4S, 2001 ST2, 1996 900 SS/CR, 1996 900 SS/SP
Stick is offline
post #3 of 5 (permalink) Old Jul 13th, 2016, 5:11 am Thread Starter
Thank you, Stick. Got some reading to do for sure. Thanks again.
Sarah
Stick likes this.
greer is offline
post #4 of 5 (permalink) Old Jul 14th, 2016, 2:03 pm
Stick's Avatar
NP, Sarah!
Stick is offline
post #5 of 5 (permalink) Old Apr 25th, 2017, 6:36 am Thread Starter
Since my valve adjustment some time back (oh man, was that hell!) I have a slow drip from the lower front rocker cover. Replacing the o ring didn't help at all; the Scrambler Forum suggested waterproof grease on the o ring and some good raps with a rubber mallet to seat the cover, and that's definitely helped, but I still have a leak. Any other suggestions? Thanks
Sarah
greer is offline
Cam belt tensioners. grrss Supersport 41 Aug 1st, 2016 3:12 am
Need help/clarification on ST3 engine timing. AGreenSmudge Sport Touring 3 May 12th, 2016 4:31 am
Help! 748 won't start after belts & valves. DesmoliFE Tech Forum 13 Apr 10th, 2016 1:21 am
Eccentric cambelt tensioner pulley nut tool PACABADA Tech Forum 10 Apr 1st, 2016 11:14 am
