Patto's Scrambler - Ducati.ms - The Ultimate Ducati Forum
post #1 of 17 (permalink) Old Apr 22nd, 2015, 8:42 am Thread Starter
turbobike749's Avatar
Cool Patto's Scrambler
Finally the little yellow beast has turned up and been pulled out of the crate. First impressions are great. Love how much fun it is to ride, and how much bottom end and mid range this little thing makes.
On went a Termi for now, but I think a Shift-Tech muffler is what I will end up with.
A powercommander 5 has been installed and is being tested and also the Dyno-jet quickshifter is working flawlessly. It is still a bit too new to be reved out on the dyno and see just how big the horses from Thailand are.
Also today I fitted a cool looking set of ProTaper bars which have transformed how it rides. So much better and firmer.
Great new little project to work on and play silly buggers on.
ID:	536265   Click image for larger version
ID:	536273   Click image for larger version
ID:	536281   Click image for larger version
ID:	536289   Click image for larger version
whowalks, MJW61 and Gary Branson like this.
turbobike749 is offline
post #2 of 17 (permalink) Old Apr 22nd, 2015, 12:53 pm
Looking good. Need more Scrambler owners talking about their bikes on here!
My FT arrives mid-May...very much looking forward to seeing how this thing rides.
Chancemoto.com | 2010 Ducati Streetfighter 1098 | 2016 Hypermotard 939 SP | 2016 1299 Panigale
DJKham is offline
post #3 of 17 (permalink) Old Apr 22nd, 2015, 2:09 pm
Dukerdr's Avatar
That's funny, last night I was in Nashville and they were uncrating their first 2 Scramblers.
'95 M900, '87 750 F1b, '95 GL1500, '06 620/800 MiniStrada...
Running on coffee and sarcasm...
Dukerdr is offline
post #4 of 17 (permalink) Old Apr 22nd, 2015, 5:46 pm
Hi @turbobike749, would you mind sharing what part no. did you use for the PCV? Did you have to modify the wiring harness in any way? What about the base map, what did you use?
Sorry for bombarding you with questions, but since this is the first PCV install that I am aware of, and since Dynojet has said they don't have an ETA for the PCV for the Scrambler, I am very curious.
Cool mods, by the way.
Loveofoldducks is offline
post #5 of 17 (permalink) Old Apr 23rd, 2015, 6:24 pm Thread Starter
The unit that I used was off a M696 and the loom all was correct length. The mapping is still on zero map as I wanted to just test for fault lights etc and the rpm was reading correctly.I didn't use the O2 optimiser as the wires for thes are incorrect. The closed loop area is still also stock. The main reason also was to be able to fit a quickshifter.
Hopefully in the near future our development of the intake-express
PUK (power up kit) will start to take shape.
We may use a different PC5 in this kit so hang 5 on purchasing a unit for now.
whowalks likes this.
post #6 of 17 (permalink) Old Apr 28th, 2015, 5:29 pm
Good news, looking forward to more updates.
www.Shift-Tech-Carbon.com
Shift-Tech-Carbon Performance- High Quality Carbon Products!
Shift-Tech is offline
post #7 of 17 (permalink) Old May 24th, 2015, 1:33 am
whowalks's Avatar
This will be interesting as I believe its just a 796 with a different map and airbox, so I would expect you can get a lot more horses out of the engine but will need to judge it with the handling of course.
Im from Perth Patto and only know you by reputation but Im sure your the man to lead the way
turbobike749 likes this.
whowalks is offline
post #8 of 17 (permalink) Old Jun 5th, 2015, 11:48 am Thread Starter
Cool Check it out !! Nearly 25% more grunt midrange
Jeszzzzus, the new Waspworks scrambler
Power Up Kit has totally blown us away with a near 25% gain of power and torque !!
Dyno graphs- This is compared to a std bike first, which we then fitted with a termi slipon and upmap and retested.
Consider this , this prototype kit just made the same torque at 3,200rpm as the others produced as a maximum at 7,400rpm.
Very excited to see how this goes !!!
https://www.facebook.com/BunburyDyno...70418499821432
ID:	559673   Click image for larger version
ID:	559681   Click image for larger version
post #9 of 17 (permalink) Old Jun 5th, 2015, 11:58 am
Wow!!!
Is this with a PCV? Will you be offering the kit?
post #10 of 17 (permalink) Old Jun 5th, 2015, 11:59 am
WickedMoto's Avatar
Good call on the handlebars - the stock bars make that bike feel like a kid's toy...
2006 999s monoposto
2012 848 evo cafe
2001 M900Sie
WickedMoto is offline
Scrambler Strada? PhilipMSPT Scrambler 2 Oct 6th, 2014 9:42 pm
Scrambler duc900 Supersport 9 Aug 29th, 2013 7:53 am
New Scrambler Rosso Classico Sport Classic 58 Aug 7th, 2013 1:48 pm
Scrambler handlebars Jo-Nathan Vintage 2 Jan 10th, 2011 5:55 am
Scrambler!!! 10531 Australia, New Zealand, and AsiaPac 0 Feb 9th, 2007 12:05 am
