Is the DQS on the 1260 tunable? - Ducati.ms - The Ultimate Ducati Forum
  • 1 Post By krisnet55
  • 1 Post By dddd
post #1 of 6 (permalink) Old Aug 24th, 2019, 4:18 pm Thread Starter
I think mine has gotten a little out of whack. Up and down have worked pretty great for several weeks but now down shifting is giving problems. Up works fine still, which I assume is because it's just cutting spark when the switch in the shift linkage says to, but wouldn't down need to be sync'd with the TPS since it needs to feed in a little throttle to down shift smoothly? First down shift is no problem since I'm rolling off the throttle when I click it down, but the next one on a closed throttle ain't there....lever doesn't budge. If I feed a little throttle in with pressure on the shifter it clicks down smoothly.....closed throttle, tho', nothing anymore. I changed final gearing, don't think that would affect it Also changed grips, which required pulling the throttle tube away from the housing so I could remove the perma-grip. I wonder if the rheostat in the housing is super sensitive to positioning. Or maybe the RapidBike unit is f'ing with it?
Tim_Shady is offline
post #2 of 6 (permalink) Old Aug 24th, 2019, 4:23 pm
DarR's Avatar
Hi @Tim_Shady
Has the problem started when you changed the gearing?
Try re-calibrating the speedometer in the menu settings and see if that helps.
2018 Multistrada 1260 Pikes Peak All purpose fun
2016 Monster 1200 R Rambunctious fun
DarR is offline
post #3 of 6 (permalink) Old Aug 24th, 2019, 7:16 pm
Can the speedo even be calibrated?
Sent from my SM-G935F using Tapatalk
Monstard is offline
post #4 of 6 (permalink) Old Aug 24th, 2019, 9:42 pm
Yes. There is a function in the menu that says calibrate.
Monstard likes this.
krisnet55 is offline
post #5 of 6 (permalink) Old Aug 25th, 2019, 4:55 pm
Lets put it this way, until the multi had a quick shifter (ie 1260) it did not have a tire re-calibrating feature.
I would definitely start their
dddd is offline
post #6 of 6 (permalink) Old Aug 29th, 2019, 2:50 pm Thread Starter
Good call, although it's called 'Tire Calibration' in the 1260 menu. At any rate, as non-intuitive as the process seemed in relationship to the QS function, it fixed the problem. I rolled along at 30mph for about 300ft. until it said the process was complete, now QS down works again.
