Anyone tried/has Quad Lock Phone Mount by Evotech - Ducati.ms - The Ultimate Ducati Forum
  • 1 Post By DarR
  • 1 Post By luigi666
  • 1 Post By DarR
  • 1 Post By walnut713
post #1 of 10 (permalink) Old Aug 21st, 2019, 6:22 am Thread Starter
Looking for an iPhone holder. Dont need it for a gps.
I came across this one by Evotech
https://evotech-performance.com/coll...nav-mount-2018
Also where the heck do you guys order Evotech parts in the USA? I ended up ordering my radiator/engine guard set directly from them. It actually ended up being cheaper and with UPS Express delivery.
krisnet55 is offline
post #2 of 10 (permalink) Old Aug 21st, 2019, 6:49 am
DarR's Avatar
I've purchased several products from EP. Quality and service is outstanding. Not cheap however but they do give a 10% forum discount.
I've ordered direct as well.
krisnet55 likes this.
2018 Multistrada 1260 Pikes Peak All purpose fun
2016 Monster 1200 R Rambunctious fun
DarR is online now
post #3 of 10 (permalink) Old Aug 21st, 2019, 6:55 am
yea, I have the evotech mount. i started with the quad lock, but found using my phone annoying. even with android auto, using my phone with gloves was not as easy as garmin gps. i emailed evotech and asked to buy the garmin adapter separately, which they kindly did also my phone, pixel 3 cannot handle the direct summer heat as well as the garmin.
i have also tried the iconic gps mount, because i thought the evo-tech mount was not adjustable and i thought it stuck out too far with the small pikes peak windscreen.. but.. turns out its really no different. having come from the BMW navigator VI which has an amazing screen, i thought the garmin 396 was going to be trash, but on the bike it works well and for my height 6'1" with seat in high position the evo-tech angle is perfect, so i put back the evo-tech after installing the iconic mount (for now).
its nice just having the gps always there and with ignition power and between that and the ducati bluetooth media controls, i see little need for my phone to be mounted.
also have the touratech security lock for the garmin 396. there are simpler mounts, but this mount has 3 anti-vibration spacers that work really well, which is why i went this way, but it certainly adds to the bulk of the entire setup..
ID:	951487   Click image for larger version
ID:	951489   Click image for larger version
ID:	951491   Click image for larger version
ID:	951493   Click image for larger version
ID:	951497   Click image for larger version
ID:	951499   Click image for larger version
ID:	951501   Click image for larger version
Ducati Multistrada 1260 Pikes Peak MY2019
luigi666 is offline
post #4 of 10 (permalink) Old Aug 21st, 2019, 8:22 am
What's the coupon code for the 10% discount?
Pard is offline
post #5 of 10 (permalink) Old Aug 21st, 2019, 9:35 am
DarR's Avatar
Hi @Pard
Q805P0D4E2V0
but that was awhile back. There was also a facebook code facebook17 but that may be expired.
Just contact Gary at [email protected]
He will give you a current code.
Pard likes this.
DarR is online now
post #6 of 10 (permalink) Old Aug 21st, 2019, 10:10 am
DarR's Avatar
@luigi666
I purchased the NaviHalter as the EP mount was not available at the time.
The EP looks really beefy. I find that the Navihalter can vibrate a bit a certain RPM.
It's not an issue however but can you comment about the vibration between both?
ID:	951517   Click image for larger version
DarR is online now
post #7 of 10 (permalink) Old Aug 21st, 2019, 11:18 am
I have and like the RAM mount very much..... You may want to look at them.
batman137 likes this.
walnut713 is offline
post #8 of 10 (permalink) Old Aug 21st, 2019, 11:31 am
@luigi666
I did not ride long enough the iconic to comment on its vibration confidently. The evo-tech is certainly not vibration free and like i said, the touratech gps lock has 3 large anti-vibration pegs that further reduce the vibrations. I also put 4 "isolate it" anti-vibration washers between the mounting plate and the evo-tech.
The evo-tech also has a rubber piece that sits against the windscreen slider. Similarly the iconic mount came with several rubber and foam pads that go between the mount the windscreen slider.
The setup I have now, evo-tech + touratech garmin 396 lock + garmin 396 is very good given the amount of vibrations coming off a ducati to begin with (i also have the full termignoni with db killer removed). as long as I am not in full acceleration, its pretty good.
Still not has good as my R1200GS (with full akrapovic exhaust) but the GS has so much less vibrations to begin with.
luigi666 is offline
post #9 of 10 (permalink) Old Aug 21st, 2019, 11:32 am
RAM is great, but for a permanent mount that you want to lock and leave your gps in, RAM options are meh
luigi666 is offline
post #10 of 10 (permalink) Old Aug 21st, 2019, 5:11 pm
Administrator
scott's Avatar
Images: 2
I have a Hondo Perfect Perfect Squeeze and LOVE it! https://shop-hondogarage.com/product...ze-phone-mount
Scott
Sacramento CA
'03 Ducati ST4S with ABS - '12 KTM 500EXC - '19 BMW R1250GSA
(Jessica Focker's) '15 BMW S1000RR - '17 KTM 350EXC-F - '09 Yamaha XT250
Some of the most asinine things people do are typically preceded by the two words "Watch this."
scott is offline
