Multistrada Enduro rear wheel removal - Ducati.ms - The Ultimate Ducati Forum
  • 1 Post By allazurra
post #1 of 4 (permalink) Old Aug 15th, 2019, 2:02 am Thread Starter
Hi, not mechanically inclined i could not find a link or video on how to remove the rear wheel of my Enduro hope someone can point me to a site, tried searching this forum and google and mostly single sided swing arm multis are shown. Thanks
snap is offline
post #2 of 4 (permalink) Old Aug 15th, 2019, 11:01 am
allazurra's Avatar
Hi Snap, the enduro rear wheel is easy, if youíve got the special socket for the rear wheel nut. Just loosen the nut ( it is tight), tap the axle out, pull the axle out from the LH side while holding the wheel up, lift off the chain, roll the wheel out backwards. For mounting the wheel, be aware of the brakedisk, make sure it seats between the pads, put the axle in after aplying grease, loosly put on the axle nut, set the chain tension even left and right (I hate using the markers on the swingarm and always use a slide gauge to make left and right the same), torque to 180 nm and admire your dirty hands!
batman137 likes this.
allazurra is offline
post #3 of 4 (permalink) Old Aug 15th, 2019, 5:02 pm
Read the post above this one.
Siddo
Siddo is offline
post #4 of 4 (permalink) Old Aug 16th, 2019, 12:59 am
allazurra's Avatar
The single sided swingarms have a higher torque and you need to make shure the wheel doesnít turn while removing the nut. The enduro (and 950) donít have this and with a breaker bar I could easily break it loose!
