SHIFTING GEAR IS TOOO DIFFICULT - Page 3 - Ducati.ms - The Ultimate Ducati Forum
post #21 of 26 (permalink) Old Aug 4th, 2019, 3:28 pm
Super Moderator
Chuckracer's Avatar
Images: 2
Before I'd pay someone to sand the clutch plates I'd heap some abuse on them and clean them the old fashioned way. Launch the thing! Ever watched a MotoGP race? Pretend the green lights just went out. Do that a couple times. Don't baby it. It's a high performance bike. Ride it like a high performance bike...not like a BMW.
Wislon and harun like this.
Chuckracer is offline
post #22 of 26 (permalink) Old Aug 4th, 2019, 3:51 pm Thread Starter
Ok.l ll try it tomorrow that way.it s almost 11.50pm here.
Thank u very much
harun is offline
post #23 of 26 (permalink) Old Aug 7th, 2019, 12:07 am
Silly question, but did you check and adjust the chain tension?
Changing gear on my Multi gets noticeably "clunky" as the chain becomes slack from use and is much smoother when it is adjusted correctly.
harun likes this.
1976 RD400 (Project), 1997 916 Biposto, 2013 Street Triple R, 2014 Multistrada 1200S
herveyw is offline
post #24 of 26 (permalink) Old Aug 7th, 2019, 12:52 am
loony888's Avatar
Chain tension definitely worth checking.
When you had the clutch reservoir cap off did you bleed the nipple inside there? often there's a big air bubble trapped at the very top and bleeding it there solves it. You may need to do it more than once to get all the air out, it's amazing how little air in the system can screw with the shift and how much air you can actually get out of the reservoir bleed nipple.
harun likes this.
loony888 is offline
post #25 of 26 (permalink) Old Aug 7th, 2019, 3:26 am Thread Starter
YES It amkes big difference to shift the gear in high speed but when I m slow the same again
harun is offline
post #26 of 26 (permalink) Old Aug 9th, 2019, 2:48 am Thread Starter
OK. I did all what you said.Non of them worked.As mechanics said that Clutch set should be replaced at all
So. as soon as this will be done, I ll let you all how the Ducati react.
thx for all ..
harun is offline
