Oil Leak after oil change - Page 2 - Ducati.ms - The Ultimate Ducati Forum
post #11 of 16 (permalink) Old Jul 23rd, 2019, 12:09 pm Thread Starter
Originally Posted by Wolverine1 View Post
I use no gasket but a product called Motoseal. Both surfaces clean and dry, then dab product around them both, assemble and fill w oil.
It appears that Motoseal is actually Permatex MotoSeal Grey, which I used: Permatex 29132 MotoSeal 1 Ultimate Gasket Maker Grey, 2.7 oz
Wolverine1 likes this.
1976 RD400 (Project), 1997 916 Biposto, 2013 Street Triple R, 2014 Multistrada 1200S
herveyw is offline
post #12 of 16 (permalink) Old Jul 23rd, 2019, 5:06 pm
Wolverine1's Avatar
Then blame not that specific product, but maybe the application. I have used Motoseal for years in various applications with excellent success (not a failure yet). It seems to me to be identical to Hondabond (all anaerobic sealers). I worked at a motorcycle shop for while and we used it for some (mostly Honda) case covers that the factory doesn't call for a gasket.
It will not work if you had any oil residue on either side, and it's not easy to keep the oil pan clean unless you wait long enough for it to stop dripping.
Clean both sides (with carb cleaner or contact cleaner, something that will remove oil residue and not leave a film), apply a film to both sides, wait a minute or 2 and assemble. Then give it about 15 minutes or so and fill motor w/ oil. Maybe your film was too thin? But you also don't want major squeeze out.
Like I said, it works fine for me.
'10 MTS1200 S
'00 VTR1000f
Wolverine1 is offline
post #13 of 16 (permalink) Old Jul 23rd, 2019, 9:22 pm Thread Starter
Spoke to a tech at the dealer, guess what? There's DucatiBond
Anyway, the tip was to let it set up for around 45 minutes before filling with oil.
herveyw is offline
post #14 of 16 (permalink) Old Jul 25th, 2019, 5:36 pm
Buy a roll of gasket material and make a gasket. It takes about two minutes if you just trace the outline of the plate. I gave up on sealers years ago and just make a new gasket once per season when I check the screen filter.
2014 Multistrada S Pikes Peak, 2017 KTM 1090 Adventure R, 2009 KTM 250XCWe
GRR_Hyper is offline
post #15 of 16 (permalink) Old Jul 26th, 2019, 8:29 am
I just checked my oil screen for the first time on an oil change this week on my 2011 MTS. Dealer had the gasket ( 78810651A ) in stock for $4 and change so I decided to go that route instead of sealant. It's been a couple days and we're leak free. For $4, will be way less mess and easier checking it next time. Definitely the way to go for me. 42,500 miles and screen looked brand new with only 1 little metal fleck.
2011 Ducati Multistrada 1200
2002 Ducati ST4S - Stealth Grey!
VaDuc is offline
post #16 of 16 (permalink) Old Jul 26th, 2019, 8:40 am
Originally Posted by 1198SP View Post
Get one of these and you'll never have to mess with Permatex again. I clean the sump filter on both of my Ducs ever oil change and this makes it much quicker
https://motowheels.com/i-8426513-cor...vel-m1200.html
I did the same thing, initial cost high but easy to do over n over even blindfolded.
Diavel or Monster?---TBD
x- 2009 RED 1198s
x- 2008 YELLOW 1098
x- 2005 YELLOW 749
x- 2004 BLUE TRIUMPH SpeedMaster
x- 2001 YELLOW 748
x- 2000 YELLOW SuperSport 750
x -1989 WHITE KTM 250
enrico is offline
