2010 MTS Sproket and Chain Question - Ducati.ms - The Ultimate Ducati Forum
  • 1 Post By TallOne
post #1 of 8 (permalink) Old May 26th, 2019, 3:29 pm Thread Starter
Joe Vincent's Avatar
Hello, i recently picked up a 2010 MTS and I am working to identify some of the upgrades and changes that have been made to the bike. It looks like the sprocket and chain may have been upgraded. Does anyone have a picture of the stock rear sprocket and chain they can share? Here is a picture of mine. Is there a way to tell by looking at them if the sprockets were redone with different number of teeth? TIA! Dealership did not have that info.
ID:	943993   Click image for larger version
Joe V
Joe Vincent is offline
post #2 of 8 (permalink) Old May 26th, 2019, 3:37 pm
40 tooth is the standard
Eric
Kudelstaart, the Netherlands
Current: MTS 1200 S Touring White
Ducatis Owned & Used:
Ducati ST4S ABS, 140.000 km destroyed by a car running a red light
Ducati ST2, 80.000 km
Ducati Paso 906, 65.000 km
Ducati Paso 750, 12.000 km
eonderde is online now
post #3 of 8 (permalink) Old May 26th, 2019, 5:44 pm
That sprocket is labelled so it is a 40T with 530 pitch. Both stock sizing. Front sprocket could be different (pull cover and count teeth 15T is stock).
2016 Multistrada 1200S Touring
2018 KTM 300XC
Hardwrkr13 is offline
post #4 of 8 (permalink) Old May 26th, 2019, 6:00 pm Thread Starter
Thank you. Looked like an upgraded sprocket based on manufacturer being SuperLite, but maybe not.
post #5 of 8 (permalink) Old May 26th, 2019, 7:52 pm
That is an aftermarket Superlite rear sprocket.
porkrind is offline
post #6 of 8 (permalink) Old Jun 1st, 2019, 2:38 pm Thread Starter
Thanks, that's why I started questioning the sprocket and chain in the first place as I wasn't sure. Chain felt like an upgrade as well, but not sure on that one either. Lot's to learn!
Joe V
post #7 of 8 (permalink) Old Jun 1st, 2019, 6:13 pm
TallOne's Avatar
That set up is all redone, to your benefit! For some reason my stock chain has thrived even after a sprocket change and 17K miles. Looking to go to 30K like my old bandit. No kinks so far...
Joe Vincent likes this.
I'm OK, you're OK
TallOne is online now
post #8 of 8 (permalink) Old Jun 6th, 2019, 11:05 am Thread Starter
Along with this redone set up, I also have the RapidEvo installed. Definitely some nice finds!
Joe V
Time for sproket and chain krsron Multistrada 18 Jul 21st, 2017 12:20 pm
