Leo Vince decat pipe intall issue - Ducati.ms - The Ultimate Ducati Forum
post #1 of 8 (permalink) Old May 20th, 2019, 2:28 pm Thread Starter
pcv57's Avatar
I finally broke down and purchased the Leo Vine mid-pipe. As I was trying to remove the front cylinder pipe, one of the bolts broke off because of excessive rust. Does anyone know how difficult (costly) it is to replace this and the best way to remove the other bolts without creating the same problem?
pcv57 is offline
post #2 of 8 (permalink) Old May 20th, 2019, 3:02 pm
mwhite5471's Avatar
Penetrating lube days in advance and maybe try loosen bolts when bike is hot.
mwhite5471 is offline
post #3 of 8 (permalink) Old May 28th, 2019, 2:52 pm Thread Starter
pcv57's Avatar
I was finally able to remove the catalytic converter and am ready to install the Leo Vince pipe. I have a couple of questions:
1. The Leo Vince doesn't seem to want to fit into the front cylinder pipe. The rear cylinder pipe went right in but the front doesn't slide together properly
2. When I connect the rear cylinder to the LV, the mounting hole doesn't line up with the bracket that the cat was bolted to. I tried to realign a few times but can't get it high enough to line up with the bracket on the frame.
3. When removing the front cylinder pipe, I snapped off one of the bolts. Does anyone know how to remove/replace it?
Thanks for the help
pcv57 is offline
post #4 of 8 (permalink) Old May 29th, 2019, 8:48 am
Sco
Sco's Avatar
Almost sounds like the wrong LV pipe , mine lined up and installed relatively easy , in regards to the snapped bolt Try drilling it out with a counter clockwise drill bit .
2011 Multi S - Laser cut Filmguard , Evotech rad guard , Ohlins Mechtronic ECU
Tuneboy-Tune Edit,CC,QS, Leo Vince decat, MWR performance air filter
Sco is offline
post #5 of 8 (permalink) Old May 29th, 2019, 11:44 am Thread Starter
pcv57's Avatar
It said right on the box it was for a Ducati Multistrada 1200. I specified the year when I bought it so I'm not sure if there's a difference. Everything seems correct except for the mounting bolt. It's about an inch lower than the bracket. I thought maybe I didn't have the rear cylinder link pipe in far enough.
There's a Youtube video on the installation. I messaged the guy who posted it and he said he had to cut about 2mm off it for it to fit
pcv57 is offline
post #6 of 8 (permalink) Old Jun 5th, 2019, 5:10 pm
Piscatory_6's Avatar
Do you need to use that little rubber dogbone looking thing that's about an inch long with holes in the ends for bolts?
Current bikes: 2014 Ducati Multistrada S Touring
Piscatory_6 is offline
post #7 of 8 (permalink) Old Jun 5th, 2019, 5:17 pm
Thanks for the help
I'm in the same situation with the front header bolts, all 3 in my case. Like mentioned already, soak in penetrant, try heat with torch, tap with hammer to maybe break loose, drill and ez-out or retap/helicoil. I have the danmoto mid and seems i may need to trim a little of the front to get that pipe fully on and flush to head.
post #8 of 8 (permalink) Old Jun 5th, 2019, 5:59 pm
LaRossa's Avatar
Images: 14
Before drilling an aluminum head try to weld a nut onto the broken stud, the heat from the welder plus the nut as the pivot point, that stud should come out no problem.
Done it before, not on my multi but it's a trick that works quite well.
[FONT="Comic Sans MS"](2007 S4Rs, 2004 MV Brutale, 2006 999R, 2007 1098S Tricolore, 2010 1198S Corse, 2010 SFS) SOLD, 2012 Multi PP (SOLD), 2006 999S, 2016 Multi PP
LaRossa is offline
WTB: Leo Vince baffle for Leo Vince decat pipe 2011 Multi Sco Parts and Accessories 1 Feb 22nd, 2019 5:35 pm
FS:Leovince Corsa 57mm Ti Full System For 749/999 kenny Parts and Accessories 5 Nov 22nd, 2018 8:58 am
Decat pipe with stock slip on impulse138 Multistrada 9 Jul 26th, 2017 7:30 pm
Leo Vince vs MIVV Suono CJC Multistrada 31 May 5th, 2016 6:01 pm
Looking for Leo Vince Can.and big THANKS !! brickflyer Multistrada 1 Apr 2nd, 2016 8:02 am
