2015 DVT idle RPMs surging/dropping and stalls - Ducati.ms - The Ultimate Ducati Forum
post #1 of 6 (permalink) Old May 14th, 2019, 2:47 pm Thread Starter
puchika's Avatar
Question 2015 DVT idle RPMs surging/dropping and stalls
I have this issue on my 2015 that's always been an annoyance and I was thinking of getting the dealer to troubleshoot it, but wanted to get some opinions
Symptoms:
  1. Somtimes when my engine is hot and while I'm stopped with the clutch lever all the way in, the RPMs will surge to over 2000 RPM then drop to the first line of the tachometer. Sometimes she'll stall when this happens. I could ride to the next stop light and she might idle just fine.
  2. Sometimes she'll stall while I'm coasting in slow traffic with the clutch lever all the way in and the throttle closed.
Anyone have any ideas what might cause this? Since the throttle is fly by wire and the idle is controleld by the computer, I'm not sure I should bother paying what is at least an hour labor for them to troubleshoot.
TIA
2015 Multi 1200 S
puchika is offline
post #2 of 6 (permalink) Old May 14th, 2019, 3:17 pm
Strega's Avatar
Sounds like an air leak in the intake. Did you remove the emissions canister and plug the lines?
Dirty air or fuel filters, perhaps.
Strega is offline
post #3 of 6 (permalink) Old May 14th, 2019, 3:30 pm Thread Starter
puchika's Avatar
I have had the emissions canister off since I picked her up. Maybe a plug fell out. I will double check that.
Thanks!
2015 Multi 1200 S
puchika is offline
post #4 of 6 (permalink) Old May 14th, 2019, 6:51 pm
Thanks!
Yep, that could be it. I had a R1100S years ago as my touring bike and after I took the canister off it would do just what you described. Found that I had not plugged one of the lines.
BSheppard is offline
post #5 of 6 (permalink) Old May 14th, 2019, 8:54 pm
Excel Addict
Punch's Avatar
Does that model have an idle air control valve?
Could be sticking or playing up.
Narrowband O2 sensor?
Richard Collins - 2001 900SSie I have a 2 strike policy - 2 no responses from a poster = no more responses from me to any post by them. I have a good memory!
Punch is offline
post #6 of 6 (permalink) Old May 15th, 2019, 10:00 am
DaveK's Avatar
I had similar symptoms when the tps was failing too... something to have checked if it's not a vac leak.
DaveK is online now
