2019 Pikes Peak heated Grips? - Ducati.ms - The Ultimate Ducati Forum
post #1 of 8 (permalink) Old Apr 18th, 2019, 4:06 pm Thread Starter
Rdaglock's Avatar
Hi all... getting out for the first few rides and breaking in the new PP. Sick bike... loving it.
Question... I have the heated grip button on the bike, however it doesn’t activate and doesn’t turn on the heated grip icon on the dash.
Anybody else run into this? Ideas? I don’t recall it being a software only option... but maybe it is. I suppose I could check fuse.
Thanks in advance.
RDAGlock
2019 Ducati Multistrada 1260 Pikes Peak
Rdaglock is offline
post #2 of 8 (permalink) Old Apr 18th, 2019, 4:11 pm
Sophomore Member
t-bills's Avatar
The PP doesn't come stock with the heated grips. You have to add them. A dealer would have to activate them to get the button to work.
Thomas Williams
2018 Multistrada PP, 2012 Hypermotard 1100 Evo SP, 1995 900SS/SP
t-bills is offline
post #3 of 8 (permalink) Old Apr 18th, 2019, 4:16 pm Thread Starter
Rdaglock's Avatar
Thanks T-Bills.... I don’t know how I missed that. Do you know if all of the heated grip hardware and guts are already installed... and it’s just enabling it in software? Or does it require installation of the hardware too?
Thanks again.
RDAGlock
Rdaglock is offline
post #4 of 8 (permalink) Old Apr 18th, 2019, 4:27 pm
Thanks again.
It would require installation of the heated grip hardware, not just the software activation.
porkrind is offline
post #5 of 8 (permalink) Old Apr 18th, 2019, 4:56 pm
Sophomore Member
t-bills's Avatar
Easy install, but you would have to purchase the hardware. Take off the handguards and the grip are held in place with a set screw. Slide off the old, and slide on the new. Given it is fly-by-wire, the throttle has a cable to disconnect/reconnect. The heated grips will also have two more cables to connect. I was able to connect up the heat cables by turning the bars to full lock and digging around above the radiator. The dealer wanted to charge me stupid money to install because they planned to take off bodywork. I got them to agree to activate if I did the install.
Thomas Williams
t-bills is offline
post #6 of 8 (permalink) Old Apr 18th, 2019, 8:57 pm Thread Starter
Rdaglock's Avatar
Thanks fellas.
RDAGlock
Rdaglock is offline
post #7 of 8 (permalink) Old Apr 20th, 2019, 12:46 am
I've got a set of heated grips off my '16 if you're looking for a set. Pm me if interested.
I took them off and put on an aftermarket set. I didn't find they put out much heat, which appears to be typical.
vfrcapn is offline
post #8 of 8 (permalink) Old Apr 20th, 2019, 12:26 pm
DarR's Avatar
Previous heated grip models do not fit the 1260. Dealer had a pair which was thrown into the purchase deal but had to backtrack as he had to order the right part for the new 2018 Multistrada.
2018 Multistrada 1260 Pikes Peak ------ 2016 Monster 1200 R
2016 Panigale 959 (gone but shall return in a new iteration)
DarR is online now
Glad to be back....2019 Pikes Peak Rdaglock Multistrada 12 Nov 28th, 2018 6:37 pm
2015+ Aftermarket Heated Grips mroberto Multistrada 4 Feb 27th, 2017 10:22 pm
Riding Two-Up Pikes Peak Vs. S-Touring jlureone Multistrada 12 Jul 14th, 2016 10:54 am
