Finally the right exhaust note! - Page 2 - Ducati.ms - The Ultimate Ducati Forum
post #11 of 17 (permalink) Old Apr 29th, 2019, 4:12 pm Thread Starter
LaRossa's Avatar
Images: 14
Originally Posted by mwhite5471 View Post
Have you got the AFR graph from the dyno?, be interesting to see where the tuner made the power tweaks.
Did you loose any MPG, 3-5?
No, never got that graph from the tuner but I did lose mpg, she's thirsty now although I keep it always in sport mode so it's to be expected
[FONT="Comic Sans MS"](2007 S4Rs, 2004 MV Brutale, 2006 999R, 2007 1098S Tricolore, 2010 1198S Corse, 2010 SFS) SOLD, 2012 Multi PP (SOLD), 2006 999S, 2016 Multi PP
LaRossa is offline
post #12 of 17 (permalink) Old Apr 29th, 2019, 4:12 pm Thread Starter
LaRossa's Avatar
Images: 14
LaRossa is offline
post #13 of 17 (permalink) Old Apr 30th, 2019, 10:13 am
DarR's Avatar
Originally Posted by LaRossa View Post
Didn't use the sc project, nasty loud but it can be toned down with drop in baffles but ended up with the arrow, imo the only one for Ducati, even the termi can that came with the PP was too loud.
Those SC-Project "racing only" cans shown are over-the-top loud. I have a homologated SC-Project exhaust on the Monster and it's loud without the baffle. BTW, as you know but for the guys here, the PP Termi can is not a silencer. It's summarily just cosmetic. The silencing is done at the stock mid-section. Using the PP's Termi with a de-cat mid-pipe is equivalent to an open pipe with no silencer.
2018 Multistrada 1260 Pikes Peak All purpose fun
2016 Monster 1200 R Rambunctious fun
DarR is offline
post #14 of 17 (permalink) Old May 2nd, 2019, 6:41 am
I tried few options with the arrow midpipe and nothing sounded like I think it should, too loud, not deep enough, so I went back and did the same thing I did to my old pp and streetfighter, arrow thunder.
A couple of tries brought it down to no db killer and 3.5" shortening, absolutely perfect noise in my opinion of course, deep as I like and loud but not half as loud as with the other cans I tested, it sounds just like the sfs I once modified.
Next week is going on the dyno for the PC V tuning, no, I don't really care about the flat spot between 2300 and 2450 rpms, I don't hang out in that rpm range at all.
I also took a tooth off the front sprocket, this is gonna be fun!!!!
So it fits, superb, any more pics of the final result?
Will the Termi slip on fit? I love the look of it. Will it be possible to slip in a dbkiller in the first part of it?
stegegjerdet is offline
post #15 of 17 (permalink) Old May 2nd, 2019, 10:06 am Thread Starter
LaRossa's Avatar
Images: 14
The termi slip on will fit, you would have to massage a drop in baffle since if you look on the inside of the termi carbon piece is almost a step down type, not a straight through.
If you don't use the baffle the termi can is almost like not having it, absolutely fantastic in decel. but borderline obnoxious. You'll need good earplugs for sure.
Worth selling it and get a good can imho.
LaRossa is offline
post #16 of 17 (permalink) Old May 2nd, 2019, 10:12 am Thread Starter
LaRossa's Avatar
Images: 14
In order to use the termi can and the midpipe I would suggest welding a resonator between the y connection and the end of the pipe, just like leo Vince did for the 2012 years, that wasn't great to look at but worked really good, I see if I can pull up a pic of it, I used it on my old 12pp
LaRossa is offline
post #17 of 17 (permalink) Old May 2nd, 2019, 10:22 am Thread Starter
LaRossa's Avatar
Images: 14
https://photos.app.goo.gl/PQFsa8KqNTciwi7F9
ID:	942203   Click image for larger version
ID:	942205   Click image for larger version
ID:	942207   Click image for larger version
ID:	942209   Click image for larger version
LaRossa is offline
Full Termignoni StreetFighter (1098/848) exhaust BearcatRR Parts and Accessories 5 May 2nd, 2018 7:49 pm
996 OEM exhaust parts problems Sitting Duc Superbikes 5 Mar 13th, 2018 5:18 pm
