Clearwater LED plug-n-play system for Multi 1260 - Page 4 - Ducati.ms - The Ultimate Ducati Forum
post #31 of 42 (permalink) Old Mar 11th, 2019, 8:05 pm Thread Starter
johnchypermotard's Avatar
Originally Posted by DarR View Post
Do these lights include all the brackets required to install them in the same location as the Multistrada's GT set-up?
i'm not sure what mounting kit Clearwater Lights will end up offering/including.
i 3D printed the adapters to allow the Darla LEDs to mount on the Ducati fog light mounting brackets ... so even if Clearwater decides not to include the additional mounting kit, one can purchase the Ducati fog light mounting brackets, and 3D print, or machine spacers to facilitate mounting the Darla LEDs.
for mounting the other LEDs that Clearwater offers (e.g.: the Krista or Erika LEDs), those can mount directly to the Ducati fog light mounting brackets, using the Clearwater mounts.
again, more data, once Clearwater finalizes what their kits will include.
2018 Multistrada 1260 S Touring
johnchypermotard is offline
post #32 of 42 (permalink) Old Mar 17th, 2019, 4:25 pm Thread Starter
got a phone call from Glenn at Clearwater Lights ... they are shooting to have the first article production piece of the CANopener for Multistradas ready for testing and fitment on my 1260 in the next week or so.
as soon as the final testing is completed and any engineering tweaks that may be required are completed, Clearwater should launch the new product as a complete plug-n-play kit with Darla LEDs. Glenn has advised he will put together a special discount pricing deal for the product launch, and i will advise the details here when available.
post #33 of 42 (permalink) Old Mar 27th, 2019, 2:07 pm
slydrite's Avatar
Subscribed!
slydrite is offline
post #34 of 42 (permalink) Old Mar 27th, 2019, 2:31 pm Thread Starter
had to put off riding up to Clearwater until at least next week. Hopefully, the weather will be dryer then too.
post #35 of 42 (permalink) Old Apr 7th, 2019, 6:27 am
subscribed
2013 Mutlistrada - matte chrome
windi is offline
post #36 of 42 (permalink) Old Apr 11th, 2019, 5:00 pm Thread Starter
At Clearwater Lights again, getting the production CANopener installed.
This is Billy doing the installation. He’s the person that Clearwater Billie brake light is named after.
A video of how to program the CANopener to manage the LED brightness and the other options, will be posted up soon on the Clearwater web site, along with photos and written instructions.
i gotta say, with the CANopener module installed to manage the Darla LEDs, the system is very cool indeed.
now i can set the brightness of the LEDs while in DRL mode (low beams on) to anywhere between 10 and 100% brightness, and not need to have the potentiometer/volume switch on the bike ... i just use a combination of "Mode" and turn signal switch presses to set and save.
the cool functionality is that no matter what brightness you have the LEDs set to run at in DRL mode, when you hit the horn, or flash the brights, or go to high beams, the LEDs turn up to 100% brightness.
i'll post up the written operating instructions ASAP, as they will indicate all the functionality/features.
ID:	940505   Click image for larger version
ID:	940507   Click image for larger version
post #37 of 42 (permalink) Old Apr 12th, 2019, 10:47 am
Motozen's Avatar
Is the Canopener plug and play? Does it require that you use the prewired fog light plug which is already on the bike?
"And those who were seen dancing were thought to be insane by those who could not hear the music"
Motozen is offline
post #38 of 42 (permalink) Old Apr 12th, 2019, 3:24 pm Thread Starter
yes, the CANopener is plug-n-play ... it literally plugs into the diagnostic port connector under the seat.
You plug the CANopener in, connect the positive and negative leads to the battery, and then plug in the wire to run to the front of the Multi, and either bolt the Darla LEDs to the factory fog light mounting brackets (as I have done in photo below), or use the fender mount brackets from Clearwater (as in other photo below).
the CANopener also has leads out of it to connect up one of Clearwater's Billie tail/brake LED lights, if one chooses.
ID:	940589   Click image for larger version
ID:	940591   Click image for larger version
post #39 of 42 (permalink) Old Apr 21st, 2019, 9:25 pm Thread Starter
currently working with Clearwater Lights on developing an alternative "Billie LED Brake Light" that will replace the rear reflector on the Multistrada.
and, when coupled with the Clearwater Lights CANopener the Billie Brake Light is an "intelligent" brake light module that utilizes sensor data carried on the CAN bus. this allows the Billie to read how hard the bike is braking in order to react appropriately to any given situation.
we will be 3D printing up a prototype housing, and field testing soon.
https://www.clearwaterlights.com/.../billie-brake-light
post #40 of 42 (permalink) Old Apr 22nd, 2019, 1:14 pm
eppy's Avatar
Any word on final kit and discount pricing?
Mark
2016 Multi S, 2010 RSV4, 2004 GSXR750
eppy is offline
Scorpio Alarms 10% off and Ducati plug and play factory connections! ant46 Ducati Motorcycle Chat 1 Aug 31st, 2017 1:38 pm
Ducati Plug and Play SRX-900 Alarm kit moto Vendor Deals 0 Aug 30th, 2017 8:07 pm
