2015 seat risers - parts needed? - Ducati.ms - The Ultimate Ducati Forum
  • 1 Post By Fearless
  • 3 Post By mabrungard
post #1 of 8 (permalink) Old Jul 30th, 2018, 10:34 pm Thread Starter
Question 2015 seat risers - parts needed?
my new-to-me 2015 multi came with the seat in the low setting, and without the risers. at i'm 6'2" i'm feeling a bit cramped and so, have ordered the 3 plastic parts below:
(3) SEAT SUPPORT FRONT: 8291D831B
(4) SEAT SUPPORT LEFT: 8291E021B
(5) SEAT SUPPORT RIGHT: 8291D981B
however, i'm not sure if i also need the accompanying screws/washers. are simply they re-puposed from the existing low setting, or are they "additional" pieces required to install the above parts? and if so, how many of each?
(6) SCREW, SPECIAL: 77214071AA
(7) SCREW: 77214411AA
(12) WASHER, NYLON 9X14X1: 85212181A
parts diagram here: OnlineDucati.com: the online shop for Ducati OEM spare parts and accessories.
thanks in advance, any help much appreciated!
the difference between "fetish" and "felony" is checking beforehand.
dr. jones is offline
post #2 of 8 (permalink) Old Jul 30th, 2018, 11:41 pm
EvilSteve's Avatar
The screws are different, someone who currently has the bike can maybe have a more specific answer. I remember being super irritated when I had to change the seat height and having to have different screws for it.
'14 Ducati Multistrada 1200S Granturismo
'18 Triumph Street Triple RS
EvilSteve is offline
post #3 of 8 (permalink) Old Jul 31st, 2018, 1:10 pm
Fearless's Avatar
I have a 2015 DVT as well. The screws are just re-purposed.
EvilSteve likes this.
2015 Multistrada S / FULL MIVV exhaust / Rexxer ECU flash
When life throws you a curve, lean into it and grab a handful on the way out!
Fearless is offline
post #4 of 8 (permalink) Old Aug 1st, 2018, 2:24 pm
For screws to raise the seat, you need 6x of this: 77214411AA. Reading the fiche I ordered two others that are not needed.
Essing is offline
post #5 of 8 (permalink) Old Aug 1st, 2018, 3:31 pm Thread Starter
thanks! and agreed on the fiche - not very clear.
i'm definitely looking fwd to sitting a bit higher up.
post #6 of 8 (permalink) Old Aug 9th, 2018, 6:23 pm Thread Starter
well, parts arrived today from amsducati (dallas). risers, screws, and nylon washers.
unfortunately, they sent 2 of the left side riser and 0 of the right side. ugh.
i suspect it will be another few weeks before i get the correct part. until then, i ride low.
post #7 of 8 (permalink) Old Sep 3rd, 2019, 2:13 pm
mabrungard's Avatar
For anyone that is lamenting the seat angle and the effect it has in driving you toward the tank, installing ONLY the front riser piece on the seat without the side pieces, does flatten the seat angle. The only bad thing about installing only the front piece is that the aesthetics are a little worse...there are gaps between the front of the seat and tank. This adjustment has been worthwhile in my experience.
The Fixer, AK-Bandit and TNMulti like this.
M. Brungard Carmel, IN
2016 Multistrada 1200, 2005 Kaw 636 Trackbike
mabrungard is online now
post #8 of 8 (permalink) Old Sep 3rd, 2019, 3:17 pm
I saw this mentioned somewhere else on this board, maybe you or another poster...can't remember. I'm gonna give this a try. If nothing else it will give me an idea of how much foam to add to the front if I go that route
TNMulti is offline
Luimoto Custom Seat Cover (2017) IcemanZR0 Superbikes 3 Mar 19th, 2017 6:48 am
Uncomfortable seat slant on 2015 Multi Triple900 Multistrada 19 Mar 17th, 2016 6:35 pm
