bike wont start - Ducati.ms - The Ultimate Ducati Forum
post #1 of 2 (permalink) Old Mar 27th, 2009, 12:57 pm Thread Starter
Question bike wont start
new battery fitted after bike unused for some time. instrument lights ok except orange light not on. bike wont start. checked fuses all ok. have been advised relay(s) may be at fault. any other advice? can anyone illustrate where relays are located as not in handbook?
thanks.
dh.de.anderson is offline
post #2 of 2 (permalink) Old Mar 29th, 2009, 7:15 am
DragonNester's Avatar
So, the kill switch is off and you turn on the ignition. As the lights come on, you hear the electric fuel pump pressurizing the fuel supply line. You push the starter button and what then..no starter engagement or starter works but no engine firing?
If the starter doesn't work I can't see why the relay would go out because of the bike being in extended storage, but the connections could be corroded.
From the 2004 Workshop manual page 556:
Starter contactor
Starter contactor (1) is secured onto
battery mount.
Disconnect the battery (Sect. P 2).
Remove the starter contactor from its
seat onto battery mount.
Undo the nuts (4) and collect the
spring washers (3).
Remove the contactor-starter motor
cable (2).
Remove the contactor-battery cable
(5).
Disconnect the connector (6) of the
starter contactor from the wiring.
Starter contactor operational
check
Apply a 12V (battery) across the
positive (A) and negative (B) terminals
of the connector.
Connect a multimeter between the
two poles [threaded pins (C) and (D)]
of the starter contactor and then
check for electric continuity (Section
P 9). If continuity is not ensured,
replace the starter contactor.
At reassembly, check that contacts
(C) and (D) are not oxidized and use
waterproof spray.
Tighten the nuts (4) to the specified
torque (Sect. C 3).
Reconnect connector (6) to wiring.
Fit the contactor fully into the battery
mount. Push until the four retaining
pegs of the mount are visible at the
side of the contactor.
Hope this is some help...can't copy the illustrations...sorry.
Also, could the problem be in the side stand switch? It can be temporarily by-passed.
RB
'04 Silver MTS
'01 Triumph Legend tt
'09 Suzuki DR-Z 400S
'09 Yamaha XT 250
DragonNester is offline
ST4S Won't start - Lots checked, ECU problem? dinskeep Sport Touring 36 Jan 11th, 2012 11:13 am
How hard is too hard to start a 1098? Noc748 Superbikes 36 Oct 19th, 2011 6:33 am
Still won't start... JDuc Ducati Motorcycle Chat 9 Nov 7th, 2008 1:48 pm
999 cold engine start parmic Superbikes 4 Jul 2nd, 2008 10:58 am
748 Won't Start paraord45 Superbikes 16 Aug 28th, 2007 8:00 am
