**New Owner Thread...Liquid Cooled MTS ENDURO...Discuss and Show Us Yours** - Page 15 - Ducati.ms - The Ultimate Ducati Forum
post #141 of 146 (permalink) Old Oct 31st, 2017, 4:12 pm
hillcountrymoto's Avatar
Originally Posted by springsyeti View Post
I just called Fay Meyers to check on my fuel gauge repair and they are waiting on parts but I was also told one of the parts is a coolant hose related to a recall. I have not received or heard of a recall on the coolant hose. Just tossing it out there for others.
I am about to take delivery of my 2017 MTS 1200S, which I had to wait on because there is indeed a coolant hose recall but its not a Federal recall. They are saying it's part of a "service bulletin" that came down from Ducati corporate on all MTS of the current generation. /shrug
springsyeti likes this.
hillcountrymoto is offline
post #142 of 146 (permalink) Old Nov 11th, 2017, 3:10 pm
Must be something new, mine was in for service in August and no mention of coolant hose.
GT_Jim is offline
post #143 of 146 (permalink) Old Nov 16th, 2017, 1:14 pm
Yes, just got this email this morning...
"We would like to inform you that your Multistrada 1200 Enduro in need of preventative service.
This service involves replacement of the water hose within the engineís cooling system. This service is precautionary; it is intended to prevent potential damage to the hose and subsequent coolant leakage, under certain usage conditions of the vehicle.
This service is completely free of charge; as such we ask that you schedule a service appointment with your trusted Ducati Service Center soon. At this same service visit, your Ducati Service Center will also check for other necessary service updates that might be pending on your motorcycle. This ensures we maintain your motorcycle within Ducatiís optimal performance specifications."
sgnden is offline
post #144 of 146 (permalink) Old Nov 19th, 2017, 7:01 pm
Coolant Hose Recall
I just posted this in the "Multistrada" forum, if interested in part #'s.
Go to Post #24
https://www.ducati.ms/forums/44-multi...-recall-3.html
2016 MTSE
superadv is offline
post #145 of 146 (permalink) Old Feb 20th, 2018, 3:05 pm
1st Gen Hyper Hooligan
complexCarlo's Avatar
Back when I first picked her up just under 3k miles...
My oh my how much has changed.
2010 Hypermotard EVO SP
2012 Multistrada 1200s Touring
complexCarlo is offline
post #146 of 146 (permalink) Old Jul 8th, 2018, 7:02 pm
SDS
SDS's Avatar
Anyone tried to fix the fuel sender? I found a YT video of a guy claiming the solder joints have to be re-soldered, then it works again. He drilled out the potting material in order to get to the bolts to disassemble it. Apparently the float triggers sensors along a slider which in turn relay info. to the display, the solder joints at the sensors eventually break from vibration.
SDS is offline
**New Owner Thread...Liquid Cooled MTS...Discuss and Show Us Yours** oalvarez Multistrada 313 May 9th, 2018 11:19 pm
