Tightening front axle on '13-'14 - Ducati.ms - The Ultimate Ducati Forum
post #1 of 13 (permalink) Old May 1st, 2016, 12:17 pm Thread Starter
Motozen's Avatar
When installing the front axle and torqueing the axle nut on the opposite side, the axle rotates. If you temporarily tighten the pinch bolts, then the axle cannot be pulled into position. There are two notches in the end of the axle. Is there a tool that fits these notches to hold the axle in place while tightening the axle nut? Or some simpler way?
"And those who were seen dancing were thought to be insane by those who could not hear the music"
Motozen is online now
post #2 of 13 (permalink) Old May 1st, 2016, 12:40 pm
North Carolina, USA
I use a Masterlock padlock to hold the axle. When closed, the shackle fits perfectly into the notches in the axle. I used to use a screwdriver, but happened on the padlock trick one afternoon using the padlock on my toolbox.
'12 Multi Touring these days
Yes, I do miss my air cooled multi...
Brand spanking new Thruxton R
mollycbr123 is offline
post #3 of 13 (permalink) Old May 1st, 2016, 10:07 pm Thread Starter
Motozen's Avatar
Not sure how the shackle would fit in the notches, but that would be a simple solution...picture?
post #4 of 13 (permalink) Old May 1st, 2016, 10:22 pm
North Carolina, USA
I can post up a pic tomorrow, but if you close the lock, hold the body and put the curved end of the shackle into the axle, as the curve widens the two arms will fit nicely into the grooves. It has to be the right sized lock.
post #5 of 13 (permalink) Old May 2nd, 2016, 12:59 am
CaptainBeard714's Avatar
I just changed a front tire today on my 2015 DVT. I used the tool from motomfg. Pretty basic, Im sure you could get by with something else, but they do make a tool. Double check you get the right one if you order it. I think the 2014 is the same as a 2015 here, but Im not sure.
DUCATI 1098 FRONT AXLE ALIGNMENT TOOL 848/1098/1198/1199/SF/MTS1200
Brandon, Southern California, 26, Drive tugboats for a living.
2015 Multistrada 1200s
CaptainBeard714 is offline
post #6 of 13 (permalink) Old May 2nd, 2016, 5:48 am
North Carolina, USA
Crummy cell pic, but there ya go. I used to have a tool that I made out of a piece of metal while fiddling around on the grinder, but it disappeared somewhere along the way. Then I just used a screwdriver for a while, until I noticed the lock on my toolbox. I've got some other Duc specific tools, but never could bring myself to spend any money on this one.
jfusaro likes this.
post #7 of 13 (permalink) Old May 2nd, 2016, 10:50 am Thread Starter
Motozen's Avatar
Aha, now I understand. Thanks for taking the time and effort to post the pic...worth a thousand words. I'll see if I can dig one up that fits.
post #8 of 13 (permalink) Old May 2nd, 2016, 1:28 pm
SDRider's Avatar
I have this tool and it works great. Highly recommend it... especially over some of the mickey mouse suggestions in this thread.
2014 Ducati Multistrada 1200 S
2012 Ducati Monster 1100 EVO (sold)
SDRider is offline
post #9 of 13 (permalink) Old May 2nd, 2016, 5:20 pm
North Carolina, USA
Good for you.
jfusaro likes this.
post #10 of 13 (permalink) Old May 2nd, 2016, 10:54 pm
DaveNZ's Avatar
Ive always done up the axle bolt till it starts to turn the axle, i lightly tighten the pinch bolts, just enough to stop the axle from turning, then torque up the axle nut, i then loosen the the pinch bolts, bounce on the suspension, to make sure no twisting of the forks, then torque up the pinch bolts,
franssenstom likes this.
multistrada 1200.. 2010... Black with full system...2016 KTM 1290 GT. Remus can and link pipe. 2018 KTM 790 fun machine.
DaveNZ is offline
SPEEDYMOTO Front Axle Slider: Ducati [25mm Hollow Axle With Smaller Nut] moto Vendor Deals 0 Apr 8th, 2016 8:29 pm
SALE: Corse Dynamics Front Axle Sliders for Ducati moto Vendor Deals 0 Mar 10th, 2016 10:53 pm
