Rider mode issue? - Ducati.ms - The Ultimate Ducati Forum
post #1 of 3 (permalink) Old Apr 20th, 2016, 9:09 pm Thread Starter
welshintheusa's Avatar
Rider mode issue?
So i seem to be having an issue, with changing riding modes on my New Multi with 300 miles. When i got it, there was no problem with changing modes on the move. Now it will not even go into that menu, when riding. I stop, it will go into the rider mode, i select a different mode accept it. Then it goes back to touring mode, no matter what is selected. Plus if i alter anything in the Rider help modes like wheelie control etc. What ever i set it as, it goes back to default settings on touring Mode. I am taking it in tomorrow, to see whats up. If i have possibly altered something in the menu, which only allows access, when not moving maybe? Some thing is not right anyways as i cant get it out of touring mode. What have i done? Or am i missing something?
welshintheusa is offline
post #2 of 3 (permalink) Old Apr 20th, 2016, 11:30 pm
johnrg's Avatar
Remember to hit the same OK button a second time to confirm the mode and hold it for 2-3 seconds. It should then hide the alternate modes on screen and flash alone on screen for a few seconds confirming the mode. If you don't hit OK the second time and hold it for a few seconds, your initial selection will revert to the prior mode in a couple of seconds. Why I only did a mode change once while moving since I am too easily distracted.
Sounds like you may be doing the above already.
2006 Sport Classic 1000 / 2013 Husqvarna TE 310R / 2015 Multistrada T
johnrg is offline
post #3 of 3 (permalink) Old Apr 21st, 2016, 9:28 am
DaveK's Avatar
I don't believe there's any way to change the way the mode selection procedure works. It sounds like it may be a button issue but before taking the bike to the dealer I'd suggest double checking your process (which is probably fine but worth reviewing).
While standing or moving, momentarily (basically treat it like a pushbutton, 1 second or less) push the Menu Enter (center right movement of the left rocker switch on the left handlebar), that should pop up the riding mode select screen.
Continue momentary depressing the same switch (center right movement of left rocker switch) until the desired mode is highlighted.
Depress and hold the same switch until the on screen display switches back to the normal display (a couple seconds). If you are moving and using throttle/brake it may ask you to release them. Note that the highlighted mode should NOT change during this step (only changes if you let go of the switch too early)
I had trouble with it initially... took some time to get used to the various controls on the bars.
If that sequence doesn't work then the first thing I'd suspect is that the switchgear is not working right.
DaveK is online now
Rear sprocket carrier issue. Torquejunkie Superbikes 17 Mar 19th, 2017 12:33 pm
1200 DVT starting issue Roox Multistrada 7 Apr 26th, 2016 4:22 pm
848 Cooling Fan issue Office Buelly Superbikes 3 Mar 8th, 2016 10:18 pm
Intermittent starting issue dSage Tech Forum 4 Jan 2nd, 2016 1:18 pm
