Pressure sensor error/reset question - Page 2 - Ducati.ms - The Ultimate Ducati Forum
post #11 of 14 (permalink) Old Aug 9th, 2019, 12:36 am
Multiplier's Avatar
Just had this warning come up on my '11 Multi. I'm wondering for those who have done it themselves, how do you determine which sensor is the bad one. Also, does the warning go off once the sensor is replaced or does it need to be reset by the dealer?
Thanks in advance for the help!
Multiplier is offline
post #12 of 14 (permalink) Old Aug 9th, 2019, 4:27 am
R0CKETMAN's Avatar
Itís been so long I can barely remember...apologies in advance
Yes light goes off as I recall. Canít remember if I had to unhook battery or not. Donít think so.
You have a 50/50 chance of getting it right the first time. Iím pretty sure I had to remove the beak.
It was an easy fix.
"Bones Heal, Chicks Dig Scars, Pain Goes Away"
R0CKETMAN is offline
post #13 of 14 (permalink) Old Aug 9th, 2019, 9:36 am
My horizontal MAP sensor failed earlier this year, Engine error but no Pressure error, the bike barely ran. ECU codes indicated horizontal cylinder MAP sensor, $120 part. The horizontal one is on the left side, behind the plastics and almost under the fuel tank. It is visible, and I managed to replace it, without removing anything but it's a tight space to work in. The vertical sensor is somewhere over on the right side. Replacing the sensor turns the warning off.
1976 RD400 (Project), 1997 916 Biposto, 2013 Street Triple R, 2014 Multistrada 1200S
herveyw is offline
post #14 of 14 (permalink) Old Aug 11th, 2019, 4:56 pm
Multiplier's Avatar
Awesome. Thank you both for the replies! Mine still runs just fine oddly. Possibly because I'm running a Bazzaz with a custom tune? Probably not, but just a thought. Sounds like the best course of action - since it's not running poorly - is ride it to the dealership, have them scan it to tell me which sensor is bad, buy the sensor, ride it home, and repair it myself. I have to take the tank off anyway... I've been putting off the dreaded fuel level sensor replacement and I've had the part sitting on my workbench for a few months now.
Fuel sensor error LaRossa Multistrada 86 Apr 5th, 2015 8:41 pm
1098 speed sensor error matt182 Tech Forum 0 Jun 23rd, 2014 2:44 am
2.1 Pressure sensor error braintoken HyperMotard 3 Jan 13th, 2009 10:51 am
Error 2.1: Pick-up Pressure error fred2602 HyperMotard 13 Feb 17th, 2008 7:55 am
ECU replacement and Throttle sensor reset wsmcycle Superbikes 3 Dec 2nd, 2006 12:09 pm
