S2R1k: Lateral play in shock rocker arm - Ducati.ms - The Ultimate Ducati Forum
post #1 of 4 (permalink) Old Aug 15th, 2019, 8:31 am Thread Starter
JonS2R's Avatar
Hey guys, I did a shock swap recently and noticed this lateral play in the rocker arm: https://giphy.com/gifs/SVlk4kYjBfjj1aV3AG
That was filmed with the rear suspension suspended so there was no weight on it. The manual says to check for play around the axis that it rotates on to see if the bearings are worn and it doesn't have any but it doesn't mention anything about side to side movement. Is this cause for concern?
2007 S2R 1000
JonS2R is offline
post #2 of 4 (permalink) Old Aug 16th, 2019, 8:39 am
elmostro's Avatar
Mine same thing, it doesn't seem to behave weird when I'm riding or weight is loaded on it.
elmostro is offline
post #3 of 4 (permalink) Old Aug 17th, 2019, 5:45 pm
It's normal. There is nothing restricting the rocker from moving along the pivot pin.
10 Bikes, 2 Ducks
pittmeister is offline
post #4 of 4 (permalink) Old Aug 19th, 2019, 3:18 pm Thread Starter
JonS2R's Avatar
Great thanks guys!
2007 S2R 1000
JonS2R is offline
