2001 Monster 900 front brake light not working - Ducati.ms - The Ultimate Ducati Forum
post #1 of 5 (permalink) Old Jul 11th, 2017, 4:31 pm Thread Starter
I'm new to both bikes and the forum, so not sure if this goes here or the technical forum, but here we are.
Just bought a used 2001 Monster 900 and because I was overexcited I failed to check if all the lights worked (I know, spare me, please). Turns out my brake light doesn't activate when using the front brake. Works fine when using the rear brake.
I don't see any disconnected cables, but I also don't know enough about my bike to know where to look. Thoughts?
And thanks in advance!
sicae is offline
post #2 of 5 (permalink) Old Jul 11th, 2017, 4:47 pm
GoHamInHogHeaven's Avatar
There are a couple small connectors inside the headlight assembly, just trace them back and make sure they're properly connected Sometimes they vibrate loose.
2003 Monster 800S
GoHamInHogHeaven is offline
post #3 of 5 (permalink) Old Jul 11th, 2017, 5:55 pm
jahjah's Avatar
And of course the connector at the brake lever assembly that gets knocked off occasionally. The may be redundantly what GoHam was describing but I would start at the lever.
2001 Monster S4
jahjah is offline
post #4 of 5 (permalink) Old Jul 11th, 2017, 7:04 pm Thread Starter
Thanks for the (quick!) reply. Could you be a bit more specific though? Like, what am I looking for? And would I be looking in the headlight casing for the brake light connector?
sicae is offline
post #5 of 5 (permalink) Old Jul 11th, 2017, 9:57 pm
That's a picture of the Monster brake light switch, if you just follow the wire into the harness, tracing along it with your finger, you will find those connectors and you can try carefully using 2 pliers to push the little bullet connectors into each other. Also make sure it's A. actually installed, maybe the previous owner took it off? B. make sure the 2 bolts holding it on haven't gone bad. Unfortunately I'm away in Louisville Kentucky at a music festival otherwise I'd just take some photos of my bike! Maybe someone else can chime in, but can he just jump the wires and see if it light up? Please don't try that before someone checks :X. A new switch is $35, fairly easy to install. Post pics of the new bike, always glad to see 'em.
2003 Monster 800S
2001 Monster Integrated rear light / turn signal jduke Parts and Accessories 0 Mar 9th, 2017 1:33 pm
Ducati 900 SS Monster S2R800 S2R1000 SportClassic Showa Adjustable Front Forks Zeaner Parts and Accessories 7 Feb 24th, 2017 5:02 pm
Monster 796 front brakes stopped working after bleeding concordeagle Monster 3 Dec 25th, 2016 10:36 am
Brembo front brake rotors - Monster / HYM, etc. cmepasu Parts and Accessories 2 Apr 26th, 2016 11:08 am
Brake light won't stay on Sahand Akbari Tech Forum 4 Mar 14th, 2016 8:01 pm
