Check Engine Light 2006 ST3S - Ducati.ms - The Ultimate Ducati Forum
post #1 of 1 (permalink) Old Jul 25th, 2019, 12:13 pm Thread Starter
Zoomie's Avatar
Oil Pressure Light 2006 ST3S
I used rubber plugs on the TBS synch nipples and one expired. I thought the Check Engine Light came on. Bad news, it was the oil pressure light. I drove home (< 5 miles) and had no expensive noises. . I replaced the synch nipples with proper metal plugs and gaskets. I started the engine and there was no Oil Pressure Light. The next day, I took the bike for a test ride and within three blocks, the Oil Pressure Light returned. The bike was running well.
Am I right in thinking and hoping this is an oil pressure and sensor issue? If so, how do I test it?
Zoomie: ST3S Lucrezia, BMW R1200RS
Gone: Guzzi Breva 1100,Bultaco Metralla & UJMCs
Last edited by Zoomie; Jul 25th, 2019 at 5:07 pm. Reason: Discovered error in thought process
Zoomie is offline
