Ducati Gas Tank Fuel Line Split in Half - Ducati.ms - The Ultimate Ducati Forum
post #1 of 16 (permalink) Old Jun 11th, 2019, 7:53 pm Thread Starter
Question Ducati Gas Tank Fuel Line Split in Half
Hi guys. I have a 98' Ducati ST2, and I have an issue inside the fuel tank: I discovered that a hose came off the fuel pump while I was riding about 2 weeks ago. After getting it back into my garage, pulling the bottom assembly out, and seeing that it was a disconnected hose, I decided to replace the old lines with new ones and obviously replaced the bottom o-ring. I put it all together (and yes, I replaced the hose line with submergible line), and maybe 2 days later: same damn thing happened again.
I got it back to my garage, pulled everything out again, and noticed that one of my new hose lines has literally split down the middle the entire way. I assume this is pressure, but I am somewhat at a loss here. Any suggestions? clogged fuel filter? bad fuel pump?
I'll try to get photos up soon.
Thanks.
Thecrocodile is offline
post #2 of 16 (permalink) Old Jun 11th, 2019, 8:01 pm
Administrator
scott's Avatar
Images: 2
I moved your thread to the Sport Touring forum, please read this on why it is not permitted in the Hall Of Wisdom forum: https://www.ducati.ms/forums/80-hall...means-you.html
Scott
Sacramento CA
'03 Ducati ST4S with ABS - '12 KTM 500EXC - '19 BMW R1250GSA
(Jessica Focker's) '15 BMW S1000RR - '17 KTM 350EXC-F - '09 Yamaha XT250
Some of the most asinine things people do are typically preceded by the two words "Watch this."
scott is online now
post #3 of 16 (permalink) Old Jun 11th, 2019, 9:39 pm
Super Moderator
Chuckracer's Avatar
Images: 2
Not uncommon with Ducati's...or KTM's...
https://www.ducati.ms/forums/56-supe...-wont-run.html
2011 KTM 990 SMT
2012 KTM 350 XCF-W
Chuckracer is offline
post #4 of 16 (permalink) Old Jun 12th, 2019, 3:55 am
Turbomart's Avatar
You did use pressure hose right?
If you cant fix it with a hammer, its probably electrical.
Turbomart is offline
post #5 of 16 (permalink) Old Jun 12th, 2019, 8:47 am
I read the thread you provided the link for. What I'm cornfused about is ~why~ is this a "common issue"? I mean, I have a ten year old FI vehicle with over 60k miles on it that hasn't had this trouble (aw hells bells, best knock wood!!).
So why is this issue a common problem on Ducati motorcycles?
Lastly, is this also an issue for 1996 900CR (carbed)? I just purchased one of those about a week ago with 17k miles on it.
Never Quit, Die Falling Forward
1996 900 CR. .....yer mom
Rex Coil 7 is offline
post #6 of 16 (permalink) Old Jun 12th, 2019, 2:05 pm Thread Starter
I did, but I just ordered 5 feet of super submersive, extreme high pressure hose line. The only other option would be to buy nylon braided metal hose, but I feel that would be very overboard. I'm just trying to figure out if there is a reason why the pressure was too much. Could it be something my bike is doing? Fuel pressure regulator? Fuel filter? I'm at a loss.
post #7 of 16 (permalink) Old Jun 13th, 2019, 3:34 am
Turbomart's Avatar
Maybe blocked or faulty regulator. Can you measure the fuel pressure?
post #8 of 16 (permalink) Old Jun 13th, 2019, 5:41 am
SS904's Avatar
OK. So it happens more than it probably should. Why? No idea. Knock on wood, it hasn't happened to me after 18 years and three FI Ducatis. In my case, I replace it with the recommended spec SAE 30R10 5/16" hose. It's expensive, but you should use it. I don't know what "5 feet of super submersible, extreme high pressure hose line" is, but it doesn't sound like SAE 30R10 which tends to come in one foot lengths for a price that makes you want to risk using regular hose. People have used regular FI hose to good effect and it's dirt cheap, but did I mention I have not had this issue????
The other sometimes overlooked item is using proper FI hose clamps. They apply pressure evenly around the entire circumference of the hose and do not damage the outer layer of rubber. If you have standard worm-gear type hose clamps, ditch them today.
I tend to store mu bikes with a full tank. Maybe that helps as well?
https://www.amazon.com/gp/product/B0...caticonvert-20
https://www.amazon.com/Breeze-FI5PB-...BHVF97AYT41YQC
tonered likes this.
Dan. "Painfully mistaking my big talk for the truth" Samantha Fish.
2003 ST4s (The Truck)
1995 916 (Junk Yard Dog)
SS904 is offline
post #9 of 16 (permalink) Old Jun 13th, 2019, 6:09 am
Yikes a mighty ... $30 bucks per foot. Well, it really doesn't matter how much more costly it is than the ~wrong~ hose ... it's the correct part for the application. It costs what it costs. It's no place to pinch pennies.
Movin' on:
Those hose clamps are the correct part for the application (as you've pointed out). Aside from the even clamping pressure those clamps also have radiused edges, which help to prevent the clamp's edges from cutting into the $30 bucks per foot fuel lines.
Thanks for digging that up Member *SS904 .... <img src="https://www.ducati.ms/forums/images/Ducati_ms_2015/smilies/tango_face_smile.png" border="0" alt="" title="Smile" class="inlineimg" />
post #10 of 16 (permalink) Old Jun 14th, 2019, 7:47 pm Thread Starter
Yup. So I bought the exact Ducati part from a dealership. The hose cost me $38 + tax. I also bought a new fuel filter just to check that off the list too; we will see what happens. I guess I can look it up, but how would you check the pressure inside the tank?
Cheers.
