Likely cause for water in oil. ST2 - Ducati.ms - The Ultimate Ducati Forum
  • 1 Post By belter
  • 1 Post By HiFlite
  • 1 Post By Iwannaduc
  • 1 Post By kaysystems
post #1 of 6 (permalink) Old Apr 14th, 2019, 7:05 am Thread Starter
I have found traces of water in the oil in our ST-2.
What are the likely causes for this?
1. Head gasket?
2. Other fault?
Thanks.
Too many old /former bikes to list here.
For now I'm happy with my -98 european 900SSie & a Multi 1000S DS -06
gundj is offline
post #2 of 6 (permalink) Old Apr 14th, 2019, 7:09 am
there is no head gasket. i'd start with the water pump seal, it's a spring loaded ceramic seal.
gundj likes this.
know all wanker
belter is online now
post #3 of 6 (permalink) Old Apr 14th, 2019, 11:13 am
For "traces" of water after a long winter hibernation, I would do nothing for a while. Thanks to combustion products blowing by the rings, there's always some water in the crankcase and thus the oil. Significant loss of coolant or evidence of oil in the coolant would require immediate investigation. This, as well as milky whitish oil seen in the level window, I've never done anything about and (so far) always disappears with warmer weather and frequent riding.
beemerboy likes this.
1998 Ducati ST2
1978 Suzuki GS1000c
HiFlite is offline
post #4 of 6 (permalink) Old Apr 14th, 2019, 12:59 pm Thread Starter
Thank´s for the answers.
Reason for my concern is that I have 4 Ducatis in the same garage, 3 aircooled and then this ST2 and only the ST2 had greyish streaks in the oil when changed.
gundj is offline
post #5 of 6 (permalink) Old Apr 14th, 2019, 6:06 pm
Iwannaduc's Avatar
This^^^
Keep an eye on your oil level. Water is heavier than oil and will sink to the bottom of the oil pan raising the oil level visible in the sight glass. If you indeed have an issue you'll see it at a higher level than you have now or had two days ago.
If you don't have an unexplainable rise in oil level then you likely just have a bit of moisture in the crank case. That needs to be burned off by an unbridled, long hard ride through the twistiest stuff you have in your neck of the woods.
.....sean
gundj likes this.
My garage: Twins:2000.5 Mille R, 2000 996, 1994 EX500 basket case 1993 900SS. Suzukis: 2004 GSXR600, 1992 GSXR750 oil boiler, 1983 XN-85 Turbo
Iwannaduc is offline
post #6 of 6 (permalink) Old Apr 16th, 2019, 6:43 am
kaysystems's Avatar
The oil breather that goes to the box under the seat can be a culprit. Water condenses up there and runs back when you finish a ride. Make sure the tube is clear, and go for a good ride soon a warm day.
David
gundj likes this.
Ducati rider since '74
1966 250 Mark3
2004 ST3
kaysystems is offline
Ducati Oil Change Kit: MOTUL 300V Factory Synthetic Oil [4 Liter] & Oil Filter moto Vendor Deals 0 Aug 2nd, 2017 11:05 pm
