ST Mirror Parts - Ducati.ms - The Ultimate Ducati Forum
post #1 of 13 (permalink) Old May 2nd, 2018, 12:34 pm Thread Starter
LGB
ST Mirror Parts
2007 ST3s:
Metal base on left mirror cracked and mirror fell off when putting a cover on the bike. I suspect it had a hairline crack before. Anyway, mirror is fine I just need the metal base that goes inside the base of the mirror. Does anyone know if this part is available separately or, where I can purchase one?
Thanks for any help!
LGB is offline
post #2 of 13 (permalink) Old May 2nd, 2018, 10:44 pm
Parts diagram only shows the whole stalk and the only other part is the rubber gasket.
IIRC, Mike Shannon made some base blocks though along with his famous mirror springs. And possibly still has an ebay store?
Maybe someone else can chime in on that?
'13 MTS GT / '99 ST2
'07 Monster 695 - Sold
post #3 of 13 (permalink) Old May 3rd, 2018, 2:41 pm
steve__d's Avatar
Mike's blocks were designed to fit between the mirror and the fairing. Not to replace the integrated block. Best bet is to find an ebay mirror off a wrecked ST. The metal part should still be OK.
LGB likes this.
2002 ST4s, Carrozzeria, Traxxion Dynamics, AL FW,
2003 ST4$ in second fastest color, Red !!
steve__d is offline
post #4 of 13 (permalink) Old May 3rd, 2018, 6:04 pm Thread Starter
LGB
Found one on ebay.
Thanks for the input.
Yep, Mike's blocks allowed the rider a clear view with out an arm or shoulder in view.
beemerboy likes this.
LGB is offline
post #5 of 13 (permalink) Old May 4th, 2018, 7:40 am
steve__d's Avatar
Mike Shannon
His email for spacers and springs: [email protected]
Current Mirror Springs on Ebay: https://www.ebay.com/itm/DUCATI-ST-M...AAAOSwbqpT7nfM
Current Mirror Blocks on Ebay: https://www.ebay.com/itm/DUCATI-ST-M...QAAOSwjyhaBEnK
Contact him directly via email and he gives a discount vs Ebay.
Steve
[email protected] likes this.
steve__d is offline
post #6 of 13 (permalink) Old May 6th, 2018, 10:10 pm Thread Starter
LGB
Thanks for that information!
In the past I ordered a set of mirror springs and IIRC there were here in a week.
LGB is offline
post #7 of 13 (permalink) Old May 15th, 2018, 9:53 am
mike shannon's Avatar
hello
j have done a set of st mirror bases in nylon on a 3d printer and all good inc the 2no 6mm tapped holes and the mirror spring bar this confirms the cad drawing ,
i hope to have some cast in alum as the metal ones you are not able to braze tig mig weld
mike
will post a few photos of the nylon test ones so you can see
Name:	st mirror base 1.jpg
ID:	912138   Click image for larger version
Name:	st mirror base 2.jpg
ID:	912146   Click image for larger version
Name:	st mirror base 3.jpg
992blkduc, LGB and spikey1973 like this.
mike shannon is offline
post #8 of 13 (permalink) Old May 15th, 2018, 11:00 am
spikey1973's Avatar
looks really nice! am intregued.
Bet you can make many people very happy with those.. including your wallet ofcourse
one advice though.. instead of copying the ducati design maybe sturdy it up at the weak spots. there is plenty of negative space that can be "filled" in for that.
i recently repaired mine with filling it in with epoxy. seemed to have done the trick.
about the casting. this should be no problem at all.
Ducati - ST3 - 2005: The red lady Current
BMW - RS1100S - 2005: The beast Wrecked
Ducati - ST4 - 2000: Lady ducati RIP
Yamaha - XJ600 - 1997: My first Sold
spikey1973 is offline
post #9 of 13 (permalink) Old May 15th, 2018, 5:19 pm
hi yes
i had a look at that as well will make them sturdy and less lighter than the ducati type i have two ways to go cnc machine center with the cad drawing or alum casting and fill in that space on them will post when i have say 6no / 12no sets as this would keep the cost down a longer production run would be great but lets try 6no / 12no set first
mike
992blkduc, Corse1 and spikey1973 like this.
post #10 of 13 (permalink) Old Apr 1st, 2019, 6:42 pm
992blkduc's Avatar
ST3 bracket?
Hi Mike
Have you progressed with making mirror brackets? I'm interested.
Thanks
'07 ST3S ABS
992blkduc is offline
