hard finding neutral - Page 2 - Ducati.ms - The Ultimate Ducati Forum
post #11 of 12 (permalink) Old Jul 22nd, 2019, 12:56 pm
Redcoat's Avatar
I was having more difficulty finding neutral after an oil change. It did not seem to happen immediately after the oil change but seemed to build up slowly.
The only thing I changed was the amount of oil. Instead of 2/3 to upper max line and I went exactly to it.
So, I bled about 100-150cc from the filler opening with a hose, mouth suction and height differential. Let it drip bleed.
Now, it's back to normal. If normal is the occasional false neutral between 5/6. That difference seems to need a firmer shift as I am normally a light shifter.
I have been thinking about the Factory Pro kit available on Desmo Times site, since he provides detailed photographic directions.
Anyone try this on the ST3s?
2006 ST3s
Redcoat is offline
post #12 of 12 (permalink) Old Aug 3rd, 2019, 10:47 am
Redcoat's Avatar
Been around 100 miles since I lowered the oil level to down to 2/3 of max height line, but I am not so certain now that the neutral is any easier to find. I can find neutral but not as easy pre-WCM, but will look at clutch lever adjustment next.
2006 ST3s
Redcoat is offline
Hard keepen’ that thing runnin’? geospencer Sport Classic 6 Aug 28th, 2006 1:01 am
Stall-No Start Until Neutral Kramer Sport Touring 15 Jun 20th, 2006 9:22 am
Mounting Hard Bags????? HB3 Sport Touring 4 Jun 18th, 2006 12:01 am
Hard to find neutral on 748 TrojanHorse Superbikes 5 Mar 13th, 2006 10:01 am
