06 Ducati ST3 Gas leaking out of gas cap - Ducati.ms - The Ultimate Ducati Forum
post #1 of 15 (permalink) Old Apr 14th, 2017, 9:16 pm Thread Starter
I haven't messed with the fuel tank other than to replace a blown off line on the fuel bump and that was last year. This issue reared its head when I brought the bike out for spring.m When the gas sloshes around in the fuel tank on bumps or hard acceleration it comes out of the gas cap in a fairly large amount. Enough to get on my jacket and make me smell like gas.
What could be causing this? Is it the seal on the gas tank or is something wrong with the little vent line that goes from the cap area into the tank?
-Barry
barryt is offline
post #2 of 15 (permalink) Old Apr 15th, 2017, 12:22 am
Still needs a life.
Bill_Anderson's Avatar
Images: 19
1) Don't fill the tank up beyond the bottom of the inside of the "neck."
2) Did you completely close the gas cap? After you think you have closed it, remove the key and push down on the center of the cap with your thumb. If it "clicks", then you had not completely closed it.
SwiftFF5 likes this.
Bill_Anderson is offline
post #3 of 15 (permalink) Old Apr 15th, 2017, 8:22 am Thread Starter
I only filled the tank up 3/4s and it still came out of the gas cap. I will check if its closed or not, but this has happened the two times I have put gas in in since it came out for the season.
-Barry
barryt is offline
post #4 of 15 (permalink) Old Apr 15th, 2017, 8:55 am
Tripod's Avatar
Make sure the vent hose didn't come off the bottom of the cap ring. Also make sure vent hose under tank isn't pinched.
SS904, tonered and mlukason like this.
Mark
2018 MV Agusta Dragster RC. Been riding since 1966
Link to Tag Game List - #400 to ? https://docs.google.com/document/d/1...it?usp=sharing
Tripod is offline
post #5 of 15 (permalink) Old Apr 15th, 2017, 9:05 am
flynnmon's Avatar
+1 on Bill Anderson's? reply, make sure you give the gas cap an extra push down after key removal , if it clicks you should be sealed.
flynnmon is online now
post #6 of 15 (permalink) Old Apr 15th, 2017, 11:53 am
Lanesmatb's Avatar
+2. I push the cap down with one hand and turn/remove the key with the other. Had the same issue once before.
Sent from my iPad using Tapatalk
2006 ST3
Maryville, Tennessee
Lanesmatb is offline
post #7 of 15 (permalink) Old Apr 17th, 2017, 4:56 pm
beemerboy's Avatar
I went through this right after picking up my ST3 a few years back. Like others here recommend, don't fill up the tank too close to the tank cap. This is noted in your owner's manual, too. Also, spray some silicone lube on the cap's rubber gasket. You'd be surprised at how much this helps the gasket expand and provide a tighter seal!
Randy,
'02 BMW R1150RT & '06 BMW K1200S
'04 1000DS Supersport & '05 ST3
beemerboy is offline
post #8 of 15 (permalink) Old Apr 18th, 2017, 9:07 am
SS904's Avatar
While it could be the cap not completely closed, it's happened before, this comment about the drain / vent lines is more plausible to me if the problem is consistent. It is also a safety issue and should be checked...
Red represents the drain line circuit. If the drain hose came off the nipple at the top of the tank, you would get fuel through the hole under the cap. It is not sealed by the cap, it is an open drain for the flange around the cap. You'll also get water in the tank if it rains or you wash the bike. If the popped off hose fell below the level of fuel in the tank, you'll get fuel out of the drain hose in the lower faring area...
Blue is the vent circuit. I don't see how you'd get fuel out of the cap here unless the hose came off AND your rubber nipple was damaged or missing. This circuit vents to the canister, unless it's bee removed, then it just vents to the atmosphere.
Dan. "Painfully mistaking my big talk for the truth" Samantha Fish.
2003 ST4s (The Truck)
1995 916 (Junk Yard Dog)
SS904 is offline
post #9 of 15 (permalink) Old Apr 19th, 2017, 9:51 pm Thread Starter
Walks outside presses down on cap... click.... I have had this bike for a year and all of a sudden I can't shut the fuel cap right? SMH
SwiftFF5, F1_nut, jahjah and 1 others like this.
barryt is offline
post #10 of 15 (permalink) Old Apr 20th, 2017, 7:03 am
44Dwarf's Avatar
Images: 10
I know on my ST4 the rubber seal at the top of the cap is semi-spring loaded and some times will get stuck up I've had the cap apart and lubed it up so the tapper and seal move easier. Yes push down for the click still.
99 Ducati ST4. Fast by Ferracci Carbon cans and Ultimap ECU
"Smok'in the competition NOT Tobacco"
"Transplant organs, Don't bury them!"
44Dwarf is offline
2009 Monster 1100 Keys & Rizomo Gas Cap 09Aircooled Monster 0 Nov 17th, 2016 11:13 am
FREE SHIFT-TECH Aluminum Quick Release Gas Cap Shift-Tech Vendor Deals 0 Oct 26th, 2016 4:28 pm
WTB: Ducati performance gas cap to 999 kenny Parts and Accessories 8 Oct 23rd, 2016 2:57 pm
Fancy gas cap ghostryderr StreetFighter 10 Oct 1st, 2016 2:45 pm
Gas cap fuel smell Torquejunkie Superbikes 2 May 18th, 2016 3:03 pm
