Pic request... Your GPS mounts /setups - Page 3 - Ducati.ms - The Ultimate Ducati Forum
post #21 of 29 (permalink) Old Jun 1st, 2014, 1:27 pm Thread Starter
2a2gtis's Avatar
Thanks guys!
The examples you have posted have given me (and others) many options!
Keep them coming! - Chris
98 Sport Tourismo 2
2a2gtis is offline
post #22 of 29 (permalink) Old Jun 2nd, 2014, 1:12 am
Maverick's Avatar
Alright then: Touratech cradle for Zumo 660 on a Desmotimes steering stem RAM-mount. The vibrations of the engine caused the GPS to lose the 12V-connection at certain RPMs so I mainly bought the cradle because the GPS is now rubber mounted, which solves the problem completely.
The ability to lock it is nice, but was not a main argument for purchase. Still very happy with it. They have a newer mount now which has supposedly been improved.
Cheers,
Mark
ID:	396370   Click image for larger version
ID:	396378   Click image for larger version
Ducati ST3s ABS '07
Now in a theater near you!
Maverick is offline
post #23 of 29 (permalink) Old Jun 3rd, 2014, 1:21 pm
simple but works
Here is my GPS mount. I use my phone in the RAM-mount. For power I have a fused 2.1 amp USB charger that is designed to be water proof. All of this is wired to the battery.
ID:	397289   Click image for larger version
v2win_lover is offline
post #24 of 29 (permalink) Old Jan 5th, 2015, 4:21 pm
Mr Leakered
tonered's Avatar
Images: 25
I'm FINALLY getting there. With a gift card from my Mother-in-Law, I finally snagged a few RAM bits for the Ural, as it was an easy fitment with the bar mount piece. It, a shorty arm, and the x-grip holder have been working great. Seeing Waze on the commute today along with a reliable GPS speed was quite nice. I'm looking forward to finally testing out the CoPilot GPS app on some FS roads.
For the ST, I found this:
Amazon Amazon
M8 bolts are used on our clip-ons and also on the Cycle Cats. For the CCs, there is an M8x1.25 hole on the inside end of the bars. They are used to support the clutch and brake reservoirs on my setup. I'm going to try mounting the RAM ball there.
I'm planning on transferring the arm and x-grip back and forth.
Have a good one.
tony b
2001 ST4 - Thumper
2013 Ural GearUp (sold)
tonered is offline
post #25 of 29 (permalink) Old Jan 7th, 2015, 6:03 pm
Mr Leakered
tonered's Avatar
Images: 25
The RAM ball mount came today.
Pretty sweet and easy setup. The top right corner of the phablet covers the lower end of the speedo. That is fine with me.
Have a good one.
tony b
2001 ST4 - Thumper
tonered is offline
post #26 of 29 (permalink) Old Jan 7th, 2015, 7:39 pm
cagivaduc's Avatar
Images: 6
nice. think I'll get that one too.
Have a good one.
'99 ST4
'85 Alazzurra
cagivaduc is offline
post #27 of 29 (permalink) Old Jan 7th, 2015, 10:04 pm
Mr Leakered
tonered's Avatar
Images: 25
I'm glad you like it. Can't wait for the ride to work tomorrow.
BTW, don't forget about breakfast on Friday, if you're available. We're going to start talking about a possible 5day tour.
And, I should be working offsite at Carillon on Monday continuing for the next couple months or so.
Have a good one.
tony b
2001 ST4 - Thumper
tonered is offline
post #28 of 29 (permalink) Old Apr 17th, 2019, 8:20 pm
Need to revisit this as I am looking for a way to mount my phone to use as a GPS. Anyone out there find a newer way to mount on an ST4 like mine. Is the RAM mount off the steering head bolt the best way to go. Also, I noted before that there is a wiring set-up for heated grips already present on the ST, so can that be used for a USB charger (I had a problem with an always on system using the stock jack....had to find a hill to jump start the beast!).
1968 Kawasaki A1SS
1970 Kawasaki A7
1971 Kawasaki A1 (basket case)
1988 Gilera Saturno 500 x 2
2004 ST4s ABS (yeller)
Mad Dog is offline
post #29 of 29 (permalink) Old May 2nd, 2019, 3:03 am
hutchingsnoel's Avatar
ST2 Navman Mount
Hi
I just made a mount for my Navman on my ST2.
Used the 2 existing 8mm bolts that bolt the handlebars on, longer bolts (40mm M8) and a pair of spacers made from 1/2" tubing and a piece of light angle aluminium
Works a treat, might try spacing the aluminium up on an angle as the Navman is a bit hard to read in the sunlight but otherwise all perfect
You could mount anything this way (cellphone included) as long as you have a case that you can screw to the aluminium.
ID:	942191   Click image for larger version
ID:	942193   Click image for larger version
hutchingsnoel is offline
GPS mounts? DAllisonfan HyperMotard 7 Jul 19th, 2012 9:24 pm
Pic request bryce86 StreetFighter 0 Jun 9th, 2011 5:02 pm
Pic request bryce86 StreetFighter 0 Jun 6th, 2011 5:18 pm
gps mounts; tricky_dickey Sport Touring 5 Apr 26th, 2007 7:37 pm
GPS Mounts. z24b Sport Touring 2 Apr 22nd, 2007 11:25 am
