'99 620SSie : 951cc engine - Ducati.ms - The Ultimate Ducati Forum
post #1 of 37 (permalink) Old Apr 14th, 2019, 3:37 pm Thread Starter
SamC's Avatar
Hi everybody,
for a few years I ride in competition (little endurance, 300 Miles, 4h30) with a 620 equipped with a stock 900ie
I am assembling a new engine:
- 748R crankcase
- 1000DS frank
- 900 conrods
- 900 cylinders with JE Pistons
- 900 cylinders head with head porting
- 748 gearbox
- 999RS fmywheel
I made some modifications on the case for the rear piston jet cooling and NJ207-ECP-C3 crank bearing
For the race (500 Miles, 6h30 this year) I intend to assemble the engine with a volumetric ratio of 11.5 : 1 to use SP98 gasoline
With pistons I currently have 13.4: 1 with DH 1mm
And here I have a dilemma, either I only change the pistons, or I put DH 1.4mm + modification of the pistons.
What do you think with the Ducati connecting rods?
ID:	940669   Click image for larger version
ID:	940671   Click image for larger version
ID:	940673   Click image for larger version
ID:	940675   Click image for larger version
'93 750SS
'99 951SSie track Bike
SamC is offline
post #2 of 37 (permalink) Old Apr 14th, 2019, 5:00 pm
i wouldn't increase the deck height - that'll make it more likely to detonate.
modify the piston or put a flat top piston in it. oem 900ie pistons are lighter than the carby ones.
know all wanker
belter is offline
post #3 of 37 (permalink) Old Apr 15th, 2019, 12:57 am Thread Starter
SamC's Avatar
That's what I think too but for an endurance race I hesitated
The old engine is a 900ie ;-)
By the way I think I'll have a good time to adjust the injection correctly with the new displacement
'93 750SS
SamC is offline
post #4 of 37 (permalink) Old Apr 15th, 2019, 2:56 am
Supermoderator - I´m special!
amullo's Avatar
Images: 313
ping @TomTom
2010 Multistrada 1200s - engine mapped by tomtom, Öhlins mechatronics SCU and alot of mods to make up for poor skills
amullo is offline
post #5 of 37 (permalink) Old Apr 15th, 2019, 6:29 am
if it has 620 throttle bodies still you could drop 1000 tables and breaks into the 620 file. or fit 800/1000 throttle bodies, set the throttle opening for the correct closed setting and use a 1000 file as a guesstimate.
how does the swingarm pivot work with the 748r cases?
know all wanker
belter is offline
post #6 of 37 (permalink) Old Apr 15th, 2019, 7:18 am Thread Starter
SamC's Avatar
I have 900SSie Throttle bodies
Unfortunatly my bike is a 1998/1999 SSie with 15M-A0, not the A8
I can not directly put a MAP of 1000 (if I'm not mistaken) in my 900SSie ECU
I was waiting for the this question
When I bought the bike the engine was already on SBK cases, but the assembly was poorly done, the axis turned directly into the aluminum cases.....
The rigging was done with badly cut tube
I installed bronze rings in the crankcase (see pictures), stainless steel spacers to make the lateral setting and external plates
ID:	940733   Click image for larger version
ID:	940735   Click image for larger version
'93 750SS
SamC is offline
post #7 of 37 (permalink) Old Apr 15th, 2019, 8:15 am
a lot less map points to change then. shouldn't be too hard.
know all wanker
belter is offline
post #8 of 37 (permalink) Old Apr 15th, 2019, 9:20 am Thread Starter
SamC's Avatar
You're right, I have a 1000MTS DP map, I just have to find the XDF to read the injection values and replace them in the MAP of my 900ie !
It will make me a good starting point to adjust
'93 750SS
SamC is offline
post #9 of 37 (permalink) Old Apr 15th, 2019, 3:53 pm
the values in the 5am fuel table are 16 bit, the 900ssie are 8 bit. try dividing the 5am numbers by 59 and using that in the 900ssie file.
know all wanker
belter is offline
post #10 of 37 (permalink) Old Apr 16th, 2019, 5:26 pm
Excel Addict
Punch's Avatar
Attached XDF for the A0 variant - just remove the .pdf
Richard Collins - 2001 900SSie I have a 2 strike policy - 2 no responses from a poster = no more responses from me to any post by them. I have a good memory!
Punch is offline
Dropping and shipping my bevel engine robax Vintage 23 Sep 24th, 2018 7:58 pm
Air Filters - Stock vs Aftermarket, and Airbox Resonance JEC Hall of Wisdom 12 Jun 12th, 2018 1:52 am
New V4 Superbike spied. kdehkordi Superbikes 107 Aug 3rd, 2017 6:00 am
