2007 Multistrada with oil leak by the countershaft/front sprocket - Ducati.ms - The Ultimate Ducati Forum
  • 1 Post By walnut713
post #1 of 3 (permalink) Old Aug 7th, 2019, 11:27 am Thread Starter
Good day all. I just wanted to let anyone who needs to know, when you believe that your countershaft seal is gone (which is what I thought was the issue with my 2007 MTS 1100s), it is usually something else.
In digging into it, I discovered a meaningless screw directly into the engine casing (into the clutch area) straight behind the front sprocket that had worked it's way out due to vibrations and just needed to be tightened and some Loctite.
Simple fix!
walnut713 is offline
post #2 of 3 (permalink) Old Aug 7th, 2019, 7:35 pm
Administrator
scott's Avatar
Images: 2
Hello and welcome to Ducati.ms. Super glad to have you roaming our halls. I copied your post to the Multi forum.
Please fill in your location information in the UserCP Edit Your Details section, that can help if there might be someone local to you give a hand or find new friends to take a ride.
Scott
Sacramento CA
'03 Ducati ST4S with ABS - '12 KTM 500EXC - '19 BMW R1250GSA
(Jessica Focker's) '15 BMW S1000RR - '17 KTM 350EXC-F - '09 Yamaha XT250
Some of the most asinine things people do are typically preceded by the two words "Watch this."
scott is offline
post #3 of 3 (permalink) Old Aug 9th, 2019, 10:01 am Thread Starter
Done Deal!
Thanks
scott likes this.
