Missing DTC option - Ducati.ms - The Ultimate Ducati Forum
post #1 of 8 (permalink) Old May 12th, 2019, 11:21 pm Thread Starter
azt108's Avatar
Missing DTC option
I noticed the other day that the DTC option is missing. The only change to my ECU was the Redline flash. Is this something that is disabled in the Redline flash or some other option within the flashing software?
azt108 is offline
post #2 of 8 (permalink) Old May 12th, 2019, 11:45 pm
Boba-Fett's Avatar
If you have disconnected the battery/ecu it will default to DTC off and will not show when you scroll through km, time, temp etc...You can turn it back on and set level again. If it isn't this then I would be asking redline.
Boba-Fett is offline
post #3 of 8 (permalink) Old May 17th, 2019, 12:44 pm Thread Starter
azt108's Avatar
Thanks Boba-Fett. How do I enable it again?
azt108 is offline
post #4 of 8 (permalink) Old May 17th, 2019, 2:00 pm
asshole online, nice in person
flynbulldog's Avatar
You probably got a flash from the non-S version of the ECU...
Vintagedesmo.com
Link to all of my bikes and builds: *Click!*
flynbulldog is online now
post #5 of 8 (permalink) Old May 17th, 2019, 3:00 pm Thread Starter
azt108's Avatar
I have a 2015 SF 848, did they even have an S model at that time? If so, would they have had DTC on one and not the other?
azt108 is offline
post #6 of 8 (permalink) Old May 17th, 2019, 6:07 pm Thread Starter
azt108's Avatar
Here is a video of me running through the options. DTC not available.
https://youtu.be/vMU2fi92548
azt108 is offline
post #7 of 8 (permalink) Old May 17th, 2019, 9:20 pm
roadkillrob's Avatar
I have seen the option when flashing and it was possible to disable it so maybe ask redline if it was disabled in yours flash file.
2012 SF848, 2015 KTM 300 XCW plated
roadkillrob is online now
post #8 of 8 (permalink) Old May 17th, 2019, 9:24 pm Thread Starter
azt108's Avatar
That makes sense, thank you!
azt108 is offline
1198: Overheated, RR failed, cooked battery, fixed but DTC error light Leanr1198 Superbikes 0 May 19th, 2018 8:15 am
Quick question on DTC SquireSCA Monster 7 Apr 13th, 2018 6:04 pm
ABS and DTC and ABS not working with Ohlins ECU Upgrade chrisjwilder Multistrada 2 Aug 11th, 2017 10:23 am
DVT Center Stand - part missing? LA_Stu Multistrada 4 Jul 14th, 2017 10:32 am
Rear set experts, in this pic is any hardware missing? fur_pig HyperMotard 0 Mar 9th, 2016 9:46 pm
