TuneECU - anyone used it on their SF848 - Page 5 - Ducati.ms - The Ultimate Ducati Forum
post #41 of 41 (permalink) Old Jul 21st, 2019, 6:58 pm Thread Starter
roadkillrob's Avatar
Originally Posted by azt108 View Post
Thanks Rob!
I was able to salvage my ECU by building a new ground from my diagnostics port. Going to try the DP slip on and see how that compares to the other slip on map.
Glad you got it going again, I didn't notice a bit difference between the Termignoni map and DP map, I like the DP map a bit better with the 02's disabled - it also seems to disable the flapper by default also.
Once you open the map in TuneEcu double check the TC setting but it should be on in the map by default and O2's will be on also, you would need to uncheck that box then write the map, then I reset the throttle adaptations usually when I am done writing the map.
2012 SF848, 2015 KTM 300 XCW plated
roadkillrob is offline
ECU Re Flash With TuneECU 234ValveDucati Sport Touring 2 Mar 22nd, 2019 3:19 am
Might be back in the Streetfighter fold soon...question about SF848 starting issues AMGnDuc StreetFighter 2 Nov 19th, 2018 9:23 pm
1100EVO motor and TuneEcu NoneMoreBlack HyperMotard 3 Aug 14th, 2018 11:50 am
1100s Hyper ecu map via TuneEcu dudz996 Tech Forum 3 Dec 30th, 2017 4:42 am
TuneEcu, OBD port. Warmkillerz StreetFighter 3 Mar 23rd, 2016 7:08 pm
