WTB: Streetfighter 848 ECU - Ducati.ms - The Ultimate Ducati Forum
post #1 of 10 (permalink) Old Jul 10th, 2019, 3:12 pm Thread Starter
azt108's Avatar
Please PM.
azt108 is offline
post #2 of 10 (permalink) Old Jul 10th, 2019, 3:24 pm
Desimoto's Avatar
Originally Posted by azt108 View Post
Please PM.
You might want to check this out.
https://www.ducati.ms/#/topics/720627
Desimoto is online now
post #3 of 10 (permalink) Old Jul 11th, 2019, 6:05 pm Thread Starter
azt108's Avatar
HERO! I just don't know if it's a simple install and flash an SF848 map. Would I need to do anything else like flash a BIN file? If so, I'm not really comfortable with that.
azt108 is offline
post #4 of 10 (permalink) Old Jul 11th, 2019, 8:41 pm
Desimoto's Avatar
Glad I could help.
Not sure about the flash, but if your setup is the same as the seller's, I would imagine it would work without a flash. I need to talk to my Ducati tech about my 748 tomorrow, I can ask him, if you like.
post #5 of 10 (permalink) Old Jul 12th, 2019, 3:29 am Thread Starter
azt108's Avatar
Originally Posted by Desimoto View Post
Glad I could help.
If I get an SF848 ECU, it should be plug and play. If I get any other ECU, I know I will have to flash a new map, but I wanted to know if there is anything other than a map that needs to be flashed, like an BIN file for example. If you could ask your tech that would be awesome!
azt108 is offline
post #6 of 10 (permalink) Old Jul 12th, 2019, 4:30 am
Excel Addict
Punch's Avatar
Bin and map are terms used for the same thing usually.
They are not really, as below.
If you have a bin file it has all the maps and the ECU does calculations on how to run the bike based on sensor inputs.
E.g. RPM, TP, Air temp, Engine temp, Air pressure, Rate of change of throttle, in some cases the gear you are in etc.
Strictly speaking (well I am typing) mapping is when you modify a map within the bin file via software like Tunerpro.
That is what I do when I get AFR logged data from someone and modify the Main fuel map and/or offset map.
I modify those maps, save the new bin and then when you then flash/write or possibly other terms the bin file to your ECU, the only thing that is different is the maps that have been modified.
Richard Collins - 2001 900SSie I have a 2 strike policy - 2 no responses from a poster = no more responses from me to any post by them. I have a good memory!
Punch is online now
post #7 of 10 (permalink) Old Jul 12th, 2019, 6:32 am Thread Starter
azt108's Avatar
That makes sense.
Is there a way to download the DP ECU Bin and flash it in any 5AM? Do I need to worry about the immobilizer?
azt108 is offline
post #8 of 10 (permalink) Old Jul 13th, 2019, 1:49 am
Desimoto's Avatar
I spoke with Daniel today, and he is under the impression that you will need to do a BIN in order to make everything work with your key, transponder, and gauges.
He has a list of what is associated with, and is specific to, the ECU, and can get it for me. But he said that if you do a BIN, you should be good to go, for around $200.00, or so.
post #9 of 10 (permalink) Old Jul 14th, 2019, 1:51 am Thread Starter
azt108's Avatar
Is there any way for me to get that list?
azt108 is offline
post #10 of 10 (permalink) Old Jul 14th, 2019, 2:47 am
Desimoto's Avatar
Sure. My 748 should be wrapped up this week... I'll see if Daniel can give it to me. I'll let you know, as soon as the information becomes available to me.
