FS: 2010-2014 Multistrada Tail Tidy - Ducati.ms - The Ultimate Ducati Forum
post #1 of 11 (permalink) Old May 12th, 2016, 3:46 pm Thread Starter
shorton's Avatar
See this thread for reason for sale:
https://www.ducati.ms/forums/44-multi...ml#post5827569
New, never installed. Fits 2010-2014 Multistradas
Install document AT THIS LINK
This is the evotech-rc.it, NOT the more typical evotech-performance Tail tidy. This is a much better made tail tidy. CNC parts and molded parts. LED license plate light. Only available importing form Italy. Cost me $182 to get it here. Sell for $152 plus shipping.
ID:	707273   Click image for larger version
ID:	707281   Click image for larger version
2014 Pikes Peak
shorton is offline
post #2 of 11 (permalink) Old May 12th, 2016, 3:51 pm Thread Starter
shorton's Avatar
The install document page 1 shows the tidy installed on a bike identical to mine.
2014 Pikes Peak
shorton is offline
post #3 of 11 (permalink) Old Sep 23rd, 2016, 11:00 am Thread Starter
shorton's Avatar
Bump. Someone asked if it was still available. It is. It will be until I post "sold" here.
2014 Pikes Peak
shorton is offline
post #4 of 11 (permalink) Old Feb 14th, 2017, 8:49 am Thread Starter
shorton's Avatar
Forgot I still had it Bump
2014 Pikes Peak
shorton is offline
post #5 of 11 (permalink) Old Oct 24th, 2017, 2:52 pm Thread Starter
shorton's Avatar
Still for sale... any reasonable offer
2014 Pikes Peak
shorton is offline
post #6 of 11 (permalink) Old Oct 26th, 2017, 9:52 am
Team Serpent's Avatar
So I read the post you point to as the reason for selling and I'm confused, hopefully you can help me out.
Is this the kit that works with panniers?
You mention drilling and tapping holes for reflector mount, does the one your selling have the holes drilled in it?
Jason
Team Serpent is offline
post #7 of 11 (permalink) Old Oct 26th, 2017, 10:25 am Thread Starter
shorton's Avatar
Sure:
1) Neither work with the stock signals and panniers as far as I know. The one I have for sale has a longer bracket available for pannier use, but the one I have for sale has the shorter "tail" bracket. I understand it will work with aftermarket signals (e.g. Rizoma). I have not verified, as I have stock signals (and no panniers). The one for sale does hold the signals out from the rear end farther. It holds them out with the plate and it may work with Panniers and the stock signals, not sure, never installed it and again, no panniers. If you follow the link for the install doc on the for sale tail tidy, I think it shows the longer "tail". I'm sure you could order that if you wanted.
2) The "drilling" was done on the one I kept. So I could attach the stock license plate holder that has the reflectors on it. I drilled and tapped 2 holes. The one on my bike (not the one for sale) is weak at the LP mount. The plate only gets picked up by 2 holes and that's all. I wanted the integrated stock side reflectors, so I used the stock LP holder with this mount. The one for sale has a full (all 4 corners) plate holder as shown in photos.
The one for sale is brand new, unused, unmodified in any way. As pictured.
Let me know if you have any other questions. Thanks, Scott. Welcome to call and chat about it if it helps.
2014 Pikes Peak
shorton is offline
post #8 of 11 (permalink) Old Oct 26th, 2017, 10:27 am Thread Starter
shorton's Avatar
Verified. Page 1 of the linked install document shows the 2 "tail" lengths. The first photo is hte longer one, the second photo is the one I have for sale, the shorter more "tidy" one.
2014 Pikes Peak
shorton is offline
post #9 of 11 (permalink) Old Oct 26th, 2017, 11:45 am
Thanks, I have panniers that I use regularly so since its not compatible I'm out.
Thanks anyways, good luck with the sale! Looks like a quality piece.
Jason
post #10 of 11 (permalink) Old Oct 27th, 2017, 12:17 pm Thread Starter
shorton's Avatar
No problem. And note these do fit with aftermarket signals I'm told. You can see in other tail tidy threads where people used Rizoma's with other brand tail tidys that hold the blinkers even closer to the bike than this one. MAY fit with stock ones. And this one can be changed to support the stock ones for sure if you order the other tail bracket. This is the Only one that can be done that way.
2014 Pikes Peak
shorton is offline
