Why does clutch fluid turn black so soon. - Page 4 - Ducati.ms - The Ultimate Ducati Forum
post #31 of 38 (permalink) Old May 31st, 2018, 1:32 pm
Tripod's Avatar
Originally Posted by DaveK View Post
Possible... was planning to vacuum bleed the whole damned thing but I'm getting air through the bleeder valve threads so I needed to pick up some teflon tape to tighten up the vacuum.
Put either Vaseline or some grease over the threads. Don't need tape.
Mark
2018 MV Agusta Dragster RC. Been riding since 1966
Link to Tag Game List - #400 to ? https://docs.google.com/document/d/1...it?usp=sharing
Tripod is offline
post #32 of 38 (permalink) Old May 31st, 2018, 2:11 pm
foler's Avatar
How you know that air go through bleeder valve threads? I think about these because in last year we are probably bleed system 30x so maybe is here problem. No leak.
foler is offline
post #33 of 38 (permalink) Old Sep 2nd, 2018, 2:16 pm
I have found it was the heat that the clutch experiences being attached to the engine. I replaced my line and the hose between the reservoir and master cylinder and it went from turning black in a week to over a month.
minitwin51 is offline
post #34 of 38 (permalink) Old Sep 2nd, 2018, 4:14 pm
SP3
SP3's Avatar
Images: 6
Originally Posted by Strega View Post
There's lot's of theories about why the clutch fluid turns black on a Ducati. Do a post search — the question goes back 15 years, but never resolved satisfactorily. All the hearsay answers are partial and left untested. Kind of like an oil thread.
Still haven't added or bled my clutch since I installed the quad ring. This 4+ years since.
https://www.ducati.ms/forums/92-hype...ml#post3710666
I'd say that's pretty well 'proven' or 'resolved'.
You say it was the heat but then say changing the hose between the res and master has lengthened the darkening period. So, it's not the engine heat.
'91 851 SP3, '66 250 Monza, '99 Monster 900 City, '98 ST2
'99 Monster 750, '66 Riverside 250, '66 Riverside 250
SP3 is online now
post #35 of 38 (permalink) Old Sep 2nd, 2018, 4:38 pm
SP3
SP3's Avatar
Images: 6
No loss of fluid level, little/no change in color/opacity, no change in lever resistance, no change in release point. Since my post in the other thread was from May '14, and I had put a couple thousand miles on it by then, I have to guess that the original install had to be during the previous winter or fall. Regardless, it's closing in on 5 years now. Original seal would require a bleed in the spring just from sitting and was responsible for some missing paint on the lower leading end of the peg bracket. No more of that nonsense.
SP3 is online now
post #36 of 38 (permalink) Old Sep 2nd, 2018, 5:43 pm
I had found the heat had degraded my lines faster than the brake lines
post #37 of 38 (permalink) Old Sep 2nd, 2018, 6:21 pm
SP3
SP3's Avatar
Images: 6
Did you replace the line between the master and slave? Your original post doesn't specifically say. Only the reservoir to master. If the original hose to the slave was rubber, yes, it was part of the issue, just like when I changed the slave seal. But, I'd guess that the slave line was Teflon which is inert. So, that leaves the reservoir hose (some form of rubber) as the only change.
It's not the heat. The running temp of your engine (and mine, for that matter) hasn't changed. The hose (and my seal) material has.
SP3 is online now
post #38 of 38 (permalink) Old Sep 3rd, 2018, 4:42 am
Turbomart's Avatar
Yes it's not heat, brake fluid can handle much higher temperatures than what the engine ever gets too.
The blackening is due to carbon black used in rubber hoses and o-rings wearing over time leaving tiny black particles in the fluid.
If you cant fix it with a hammer, its probably electrical.
Turbomart is offline
EVR Slipper Clutch - MUST SEE!!!!!!!!!!!! wrichards Superbikes 20 Nov 20th, 2007 10:46 am
need help guys (clutch basket) ThePharaoh Ducati Motorcycle Chat 10 Jul 21st, 2007 5:47 pm
Clutch Fluid Question EGGMAN Sport Classic 5 Mar 20th, 2007 1:02 am
Lock-up in the front!!!! StavesacredarK Superbikes 2 Apr 5th, 2006 11:10 am
