Chain lube - Page 5 - Ducati.ms - The Ultimate Ducati Forum
post #41 of 44 (permalink) Old Jan 5th, 2011, 7:40 am
latte committee's Avatar
I use a Scott Oiler
First few fills were the Scott Oiler products.
They seemed to work fine, except for being a tad messy until I got the flow rate adjusted correctly. After which it still left a noticable film on the LHS of the back end.
Have tried ATF, which is 1/4 of the price, and readily available.
Seems to do the job, but does "throw off" more than the Scott products.
Have used spray cans of chain lube before, but there are better methods.
Years ago I used a product named "Duckhams"
It came in a tin about 12" dia and 6" high.
It contained a 'Secret Formula" of 11 herbs and spices, suspended in a foul smelling grease compound.
Place on the stove top hotplates, and heat until the grease liquified.
After cleaning the chain with kerosene, immerse it in the grease tin.
Simmer for 10 minutes, then hold it above the grease tin and allow to drain until cook.
The downside to the Duckhams treatment was that it could only be done whilst mum was out of the house, because it caused a stench throughout the house.
latte committee is offline
post #42 of 44 (permalink) Old Jan 7th, 2011, 4:35 am
DukeDesmo's Avatar
Images: 197
Wurth dry chain lube...
Doesn't pick up much grime, doesn't fling all over the wheel, best I've tried;
916, M900 & Guzzi LeMans II
DukeDesmo is offline
post #43 of 44 (permalink) Old Jan 25th, 2011, 10:41 pm
Images: 5
ya but your in the UK
2007 Yellow 1098
"The specific purpose of the desmodromic system is to force the valves to comply with the timing diagram as consistently as possible. In this way, any lost energy is negligible, the performance curves are more uniform and dependability is better."
Alpha is offline
post #44 of 44 (permalink) Old Jan 29th, 2011, 12:49 pm
Ric
Ric's Avatar
Dupont teflon multi use.No mess.
2001 Goldwing 1800
2009 Hyper 1100S
Ric is offline
Chain Cleaning, Waxing and WD-40 Shazaam Hall of Wisdom 61 Jan 15th, 2016 6:49 pm
748: lube the chain without a rear stand? keef Superbikes 22 Sep 6th, 2013 3:20 pm
Chain Inspection and Freeplay Adjustment Shazaam Hall of Wisdom 2 Oct 2nd, 2012 11:37 am
Chains and oiling duckbrand Superbikes 31 Mar 21st, 2008 2:33 am
