1098 Engine Oil- Shell Ultra any good? - Page 3 - Ducati.ms - The Ultimate Ducati Forum
post #21 of 25 (permalink) Old Nov 18th, 2010, 11:51 am
Images: 5
Originally Posted by galaxy View Post
For a given set of conditions in a given motor
These are the key words here. Oh and what's wrong with changing it every 3000 miles? I happen to agree with ole pops on that one. How often should we be changing it then?
2007 Yellow 1098
"The specific purpose of the desmodromic system is to force the valves to comply with the timing diagram as consistently as possible. In this way, any lost energy is negligible, the performance curves are more uniform and dependability is better."
Alpha is offline
post #22 of 25 (permalink) Old Dec 2nd, 2010, 11:13 am
galaxy's Avatar
Images: 27
The answer is it depends. My only point being is a blanket 3,000 miles for the sole reason your dad taught you that is not the answer and nothing but a waste of money...depending on what you're doing with your bike. Oil technology is far too superior for that mentality these days. My Mulit that got nothing but highway, 6-9,000 or once a year. My track bikes...3,000 or once a year...but that's on Amsoil. The absolutely only testimate to what your oil is capable of is oil analysis. Outside of that, you're making a guess, and barely an educated one. Does every 3k hurt the motor? No, of course not. Hurts your pocket book if that's a factor and the environment.
There is no scenario you can convince me of that a 50 weight oil is better in a Testastretta than a 40. But, your dad probably taught you that heavier is better also anyways, so the point for you would be moot. You probably think these race teams run 60 weight too. Funny how every engine manufacturer in the world is building motors for thinner and thinner oils for all operating conditions...Honda (motorcycles) has already gone to a 30 weight, just about every car is at a 20, and Honda (cars) are looking into 10 weight oils. Yes, xW10...the second number.
www.ducati-owners-group.com
galaxy is offline
post #23 of 25 (permalink) Old Mar 31st, 2011, 8:39 am
Hazzbin's Avatar
Listen to Galaxy, he's absolutely right. You want oil that's thick enough to give adequate oil pressure and no thicker. Your dads were wrong back then and they still are now. Too thick an oil will not dissipate heat properly and under high pressure can actually give worse protection.
As far as your local temperature, that's pretty much immaterial to the oil in a running engine once it's warmed up. It doesn't matter whether it's 98 or 55 degrees outside, two identical water cooled engines being run the same way will have almost identical oil temperatures. Air cooled engines will have a slight variance, but unless they're being heavily abused, it's still not much.
Formula one engines, which rev to 18,000 rpm and will be used for more than one race use 5 weight oil.
Rotella T6 5W-40 for me. Plenty of others work just fine too.
Hazzbin is offline
post #24 of 25 (permalink) Old Apr 24th, 2011, 11:16 am
rc51eviltwin's Avatar
My $.02,i never over heated a bike until i ran a 50wt synthetic in my cbr1000.
'02 998 Ducati
'02 748 Ducati race
'07 Aprilia RSV1000R
'07 Aprilia RSV1000R race
'08 KTM Superduke
'07 GSXR750 suzuki endurance
'08 cbr1K Honda race FOR SALE OR TRADE
'07 CBR600 Honda race
'07 1098S racebike
rc51eviltwin is offline
post #25 of 25 (permalink) Old Jul 30th, 2011, 10:04 pm
shell rotella full synthetic is very good stuff
pork burrito is offline
What to do, what to do? Rebuild, motor swap or 1098??? Suggestions? desmofetish Northern California 16 Oct 8th, 2007 2:28 pm
1098 at Good Times mrmuddy Northern California 22 Feb 18th, 2007 11:45 pm
another 1098 pic(very close and with good quality) ultras998s Superbikes 14 Sep 15th, 2006 1:14 pm
Cooling System Overheating rob Hall of Wisdom 1 Jul 18th, 2006 2:42 pm
