Oil brand and service life?? - Page 6 - Ducati.ms - The Ultimate Ducati Forum
post #51 of 55 (permalink) Old Dec 18th, 2017, 2:34 am
elevated's Avatar
Hi. In the our region we usually use two type of synthetic oil 10W40 for liquid cooling engines and 20W50 for air cooling. 15W50 fits for both systems. Change interval is 5000-6000 km is normal for it, if you dont use bikes often as racing bikes on the tracks. I use Eni brand.
elevated is offline
post #52 of 55 (permalink) Old Dec 18th, 2017, 6:02 am
some696's Avatar
I use shell advance 15w50 and change it every year or 12000km as per ducati manual. I have never had a problem with this oil on a air cooled engine all year. My winters are here around 5-10C and summers around 28-35C
696 - MY2013
some696 is offline
post #53 of 55 (permalink) Old Jan 25th, 2018, 10:35 pm
Turbomart's Avatar
I also read the blog from 540 rat about his oil testing. I'm inclined to believe in his totally independent results more than what a company says about their or a competitors oil. He actually purchased the oils tested or people sent it to him so it is off the shelf stuff and no bias.
Based on his findings I've been using Castrol 20w-50 long life which is formulated for higher mileage engines. I have had the oil tested after 6000 km and it came back all within normal range with minimal viscosity drop and most of the zddp still available.
If you cant fix it with a hammer, its probably electrical.
Turbomart is offline
post #54 of 55 (permalink) Old Jan 26th, 2018, 12:43 am
PhilBoncer's Avatar
Any full synthetic that is formulated for motorcycles will be fine. If you have a dry clutch, you dont even need the oil to be formulated for motorcycles. I used whatever motorcycle synthetic was available in my M900 Monster, changed at 5K to 6K typically (but sometimes as long as 8K), for the 24 years and 265K miles I had that bike, and it never needed a rebuild of the engine or transmission. Your needs probably wont exceed that.
PhilB
1993 Ducati Monster M900, bought new, 265K miles, killed by minivan 30Oct17. 1995 M900, was ex-wife's bike, now mine again.
PhilBoncer is offline
post #55 of 55 (permalink) Old May 29th, 2019, 11:52 am
max_gain's Avatar
Ive always used manufacturers fully synthetic, Shell Advance Ultra 4T 10w-40 Performance Synthetic Bike..
max_gain is offline
Changing oil on my new 98 ST2 today--what weight/brand oil to use wildwestrider Sport Touring 41 Sep 26th, 2013 2:36 pm
Brand new boots life spend adlyn Apparel and Accessory Chat 4 Mar 1st, 2013 12:19 pm
service life pizza Superbikes 3 Oct 30th, 2006 7:11 am
Clutch life under severe service? MarcS Sport Touring 5 Jun 29th, 2006 2:56 pm
