Quick question about red key replacement - Ducati.ms - The Ultimate Ducati Forum
post #1 of 18 (permalink) Old Jul 14th, 2008, 5:11 pm Thread Starter
I have a chance to pick up a Ducati Monster pretty cheap that has one black key, no red key and being a Duc owner I understand the severity of that one ignorant engineering feat by Ducati tied to the red and the ignition (and yes, I am an engineer).
I believe I read on here somewhere that there is now someone making an over-ride key so that one doesn't have to buy the $2000 worth of guages and electrics.
Any help would be appreciated.
RedBrutale is offline
post #2 of 18 (permalink) Old Jul 14th, 2008, 5:24 pm
ducsbill's Avatar
You might be thinking of this post https://www.ducati.ms/forums/showthread.php?t=40653 which had information about getting replacement black keys.
Bill W.
2005 Ducati ST3, Black
2007 Ducati MTS 1100S, Black
Rantoul, IL
ducsbill is offline
post #3 of 18 (permalink) Old Jul 14th, 2008, 5:37 pm Thread Starter
Thanks. I just called and he charges $55 for two keys...but
Bill W.
But I also read somewhere that someone is now making an over-ride for the red key based on your black key. Supposed to have been on Ebay and was like $500 guaranteed to work.
post #4 of 18 (permalink) Old Jul 14th, 2008, 6:23 pm
Turbo's Avatar
Don't see how this can be possible. I've never heard of any kind of 'master key' that can override a RED key. Each key has a unique code and that code gets stored in the immobilizer. There are places on the web that can clone the code of an existing key to a new key, but you physically have to have the RED key to be able to clone it.
Mark (Turbo) Trbojevic
2016 WHITE Multistrada Enduro
2015 GREEN Scrambler - Urban Enduro
Turbo is offline
post #5 of 18 (permalink) Old Jul 15th, 2008, 12:29 am
I hear airplanes
TAftonomos's Avatar
If you have the Red key, you can clone new black keys
If not, you can take your black key to a locksmith with a cloner and he/she/it can do it for you.
Programming with the Red key, you must program 2 black keys....not one, not 3, but 2.
Guy on Ebay sometimes runs an add for making you a new red key....for $500.
Only reason the red one is important is to be able to self-clone more black ones.
Keys are $35 each at the dealer, pick up a few, have them cut/cloned by a locksmith, and go riding
The roads are flat I bought a harley!
TAftonomos is offline
post #6 of 18 (permalink) Old Jul 15th, 2008, 1:29 am
axismotorrad's Avatar
Not to encourage or inform those thinking of stealing a bike, but... if you replace the ECU you will not need a red key, so if there is a DP ECU or Nemesis available that will run your bike, you could kill 2-3 birds with one stone and both hop up the bike and avoid the red key in one simple operation. Totally dependent on your model and what's available for it, of course.
axismotorrad is offline
post #7 of 18 (permalink) Old Jul 15th, 2008, 2:41 am
Turbo's Avatar
Do you know this for a fact because of personal experience? The reason I ask is because what you say does not correspond with what I've been told. There's a lot of misinformation going around about immobilizers, ECUs and key codes. This is my basic understanding of the whole affair.
If you replace a coded ECU with a new one and you have a valid BLACK key, you can start the bike just fine. The ECU will remain uncoded and you can use it on another bike if you need to. However, if you use the valid RED key to start the bike, the ECU will become paired with the immobilizer (i.e. coded) and cannot be used on a different bike from that point on.
If you replace a coded ECU with a new one and you have an invalid BLACK key (i.e. a BLACK key that is not recognized by the immobilizer), the bike won't start. The immobilizer will not send a start signal to the ECU.
The key to success here is the immobilizer. That's where the valid and recognized key codes are stored. If you don't have a RED key, you cannot program any new BLACK keys into the immobilizer. If you have a valid BLACK key, you can clone it to create a spare key but it will share the same code as the original. If the immobilizer stops recognizing that code for whatever reason, both keys will be useless.
Turbo is offline
post #8 of 18 (permalink) Old Jul 15th, 2008, 6:53 am
I hear airplanes
TAftonomos's Avatar
Absolutely incorrect
Based upon personal experience....
The DASH and the key are the immobilizer. You can juggle ECU's all day long, but once the dash has been coded to a key, it won't do anything.
The immobilizer system works by reading the key, and sending a signal to the ECU from the dash. The DASH is what houses the immobilizer, and what sends the signal to the ECU telling it it's OK to start.
I don't know where all the mis-information comes/came about, but I've messed with multiple bikes now, and had 4 or 5 dashs/locksets pass through my hands, and thats how it works.
Dash/lockset are coded together. You can swap in a virgin ECU, but that doesn't change the need for a red key at all. You would still need a red key to "code" additional black keys (and you can only do 2 at a time, so 2/4/6/ etc).
The DP ECU is just a tuned ECU, it doesn't get rid of anything.
The Nemisis, OTOH, will remove the immobilizer completely.
post #9 of 18 (permalink) Old Jul 15th, 2008, 8:26 am
SS904's Avatar
Originally Posted by TAftonomos View Post
The DASH is what houses the immobilizer.
I have no experience dealing with the keys and whatnot (thankfully), but I can tell you that not all bikes have the immobilizer in the dash. On my 03 ST4s, it is a separate little black box under the headlight fairing.
Dan. "Painfully mistaking my big talk for the truth" Samantha Fish.
2003 ST4s (The Truck)
1995 916 (Junk Yard Dog)
SS904 is offline
post #10 of 18 (permalink) Old Jul 15th, 2008, 8:42 am
I hear airplanes
TAftonomos's Avatar
I apologize, I thought we were talking about the xx9 superbikes.
I do not have any direct experience with the monster's immobilizer. It would, however, be more than safe (IMHO) to say that the immobilizer ISN'T in the ECU.
Question about Metal Fuel Quick Disconnects? RoverGuy04 Superbikes 2 Apr 21st, 2008 4:20 pm
power commander and red key query Shalei Superbikes 2 Feb 29th, 2008 5:41 am
quick exhaust question... quackattack Superbikes 0 Jan 16th, 2008 12:46 pm
ST3s ABS ECU and replacement muffler question charlieST3s Sport Touring 2 Feb 15th, 2007 9:44 pm
question about brake replacement dpm Sport Touring 0 Oct 11th, 2006 5:34 pm
