» Site Navigation |
» Motorcycle Forums
» Buyers Guide |
» Links |
Jul 24th, 2009, 3:03 pm
#1
Power Commander III USB - 2003 ST4s - Software Problem
I searched long and hard with no specific solutions to this problem. I just installed a PCIII and it works fine according to the lights on the unit. The problem is that my computer will not recognize the PCIII via the usb cable. The software simply says no power commander connected. I do not even get the little USB symbol in windows.
My troubleshooting so far:
Checked all connections.
Plugged and unplugged USB several times at the unit and computer.
Rebooted the computer while the USB was plugged in and bike running.
I thought maybe someone here had a similar problem and found a solution.
Thanks!
Jul 24th, 2009, 3:56 pm
#2
Check to be sure you have the most current drivers for the OS you're running. Are you running Vista X64 by chance? I am and have had a few problems with hardware support.
2001 900SSie (gone, but not forgotten)
2003 ST4s Senna (the stealthiest color!)
A man said to the universe:
"Sir I exist!"
"However," replied the universe,
"The fact has not created in me
A sense of obligation."
Stephen Crane
Jul 24th, 2009, 4:50 pm
#3
Make sure the bike is running or use the 9V thingy. If the PC is not powered you won't be able to connect to it. Maybe you are already doing that...
Doesn't hurt to try a different usb port and cable.
**RALLYSTAR**
2006 Ducati ST3s
Jul 24th, 2009, 9:51 pm
#4
Thanks for the inputs. I am using Vista 32 bit. I also tried Windows 7. I also tried all of the USB ports. The power commander was powered on the bike and responsive to throttle inputs.
I test drove the bike today, and the low end feels real smooth, but from mid (6K+) the bike actually feels more sluggish. I am surprised to find usable power in the 3-4k range. Before it was a little jerky in this range. I may end up just trying to find some dyno time, but not sure the USB part is working. It will be a couple of weeks before I get the chance for that.
I just remounted all of the plastics, and will live with it for now. I did leave a USB cable zip-tied to the frame where I can get to it without the hassle of the plastic.
Keep your thoughts coming. I appreciate it.
Jul 24th, 2009, 11:33 pm
#5
ST & SC Junkie
Not specific to Windows or the PCIII, but some USB devices draw too much power from the PC, and need a powered hub to connect.
PC -> Powered Hub -> Device (PCIII).
I have a printer, camera and keyboard that won't work unless plugged into such a hub.
Cheers
Current pastimes:
2007 Sport 1000 SE #84
2004 ST4s
Jul 25th, 2009, 3:57 am
#6
Life is too short to worry !
I had this problem and frustratingly I cant exactly recall what resolved it but I think it was fitting the 9v battery.
I would strongly recommend the Dyno time as it is worth it , where did you get your map from ?
 02 ST4s - K&N , PCIII , 15/42T
Jul 25th, 2009, 9:37 am
#7
I may try the powered hub. I believe I have one laying around.
I do not have the 9v adapter. Bought the PC III used from another member here along with the Sil Motor cans. He had the same year and model bike as me. Not sure if the map is custom or a pre defined one. He bought the bike with the cans and PC III already on the bike, and decided to go with the stock cans.
I may have to purchase the 9v adapter. I will look around for that also.
After thinking about it more, it seems the TPS input from the PC III may be a little off, not allowing full throttle input, and insufficient fuel to get full power.
Jul 26th, 2009, 7:05 pm
#8
Had a USB camera that stopped working once.
Had an issue with USB 2.0, disabled the USB 2.0 Enhanced controller in Computer Management area of XP, and everything has been fine.
Assume all other USB devices are operating fine for you?
Jul 26th, 2009, 7:36 pm
#9
Yeah, all USB ports verified working. Also, verified the USB cable I have connected to the PC III was working with other devices. Thanks.
Jul 27th, 2009, 8:15 pm
#10
Make sure the USB cable is pushed *ALL* the way into the PC3...
Marc Schatell
Winston-Salem, NC
'02 ST4s
| Thread Tools |
| Display Modes |
Linear Mode
