British Motorcycle GearBikeBanditMcCoyMotorsportsMotorbikeUniverseLeslie Kay's
Go Back   Ducati.ms - The Ultimate Ducati Forum > Ducati Motorcycle Forums > Ducati Motorcycle Chat
Thread Tools Display Modes
Old May 23rd, 2006, 11:12 am   #11
yellerduck
yellerduck's Avatar
cracked neck tube
"I know the earlier SS900's had issues with cracked frames at the neck tube/steering tube weld, but anyone know if the SS750 had the same problem?"
Yep, mine is cracked.
yellerduck is offline   Reply With Quote
Old May 23rd, 2006, 12:03 pm   #12
Desmo_Demon
Desmo_Demon's Avatar
Ouch....I hope you didn't just now find out. Some people say that it is an easy reweld fix and not worth the effort of a frame replacement (and the labor involved) with trying to get DNA to replace the frame. Is this why you asked about the white frame? Are you planning on getting it welded up and possibly reweld the frame?
Personally, I think the white frames just look *right* on the older SS bikes, but they can be a bare to keep clean. At least the white will be a little easier to touch-up than the gold/grey frames. I think a black frame with a yellow bike looks great and a red frame with a red bike looks good, too.....a silver frame may look pretty good with your 750 with all the silver on the fairings.
Places I've Been on Two-Wheels:
IBA #32735
"Chrome is to Harley-Davidson as carbon fiber is to ____________"
Desmo_Demon is offline   Reply With Quote
Old May 23rd, 2006, 12:16 pm   #13
yellerduck
yellerduck's Avatar
frame
yes, I plan on getting it welded and repainted. I thought about silver, but for some reason I want to go with white. It may work out visually because there is white in the large Ducati stickers.
Old May 23rd, 2006, 12:36 pm   #14
Stick
Stick's Avatar
Howdy Yeller':
No surprises with the Desmodomics. They've been the same since 1979 for the belt driven engines, when the prototypes started. Wouldn't surprise me a bit if the rockers, cams, etc. were interchangeable with present day 2V. Only thing in the mid/late 80's were the rear exhaust on the rear cylinder. Before that the carbs were on "the back side" of each head.
Hot looking bike. Reminds me of the '85 F1A with a lot of nice trellis frame to gawk at.
Stick
Try this home-cure-all: Shove a DUC between your legs.
Present DUC: 2003 ST4S Yellow!
Past DUCs: 1998 ST2, 1981 500SL Pantah, 1985 MHR Mille, 1987 Paso Limited, 1995 916 mono
Other brands (past):
1978 BMW R100RS Motosport, 1978 R100S, 1981 Moto Guzzi V50 Monza (wife's bike), and a long list of Hondasakizukis
Stick is offline   Reply With Quote
Old May 24th, 2006, 8:26 am   #15
duc97sp1
The early 90s 900ss had problems with the frame cracking at the steering head. They also had a VIN plate riveted to the frame and they cracked at the rivets. Too many wheelies From 95 or 96 on the frames were beefed up and somewhere along the line they quit using the riveted plates.
Ducati has been very accomodating with replacing frames long after the warranty expired and depending on the dealer labor was also included. Turn around times for the frames could be lengthy so using a *competent* local welder was an option.
As far as a white frame, I think the early 90s red 900ss with white wheels & frame was a real looker but I don't think it would look so good on the Sport. The red frame & wheels really set it apart, imho.
"Hot looking bike. Reminds me of the '85 F1A with a lot of nice trellis frame to gawk at."
Yup, the Sport was essentially an F1 chassis with "economical" components, ie forks, shocks & the infamous Weber carb.
George
97 900sp
90 750 sport - sold
850 commando
duc97sp1 is offline   Reply With Quote
Old May 24th, 2006, 8:46 am   #16
Motophoto
Motophoto's Avatar
I have a 1995 Ducati SuperSport 900 SS SP and the frame cracked on it. Ducati did give me a new frame, this was about 7 or 8 years ago. The swing arm also cracked and had to be fixed. Funny... if it was a Honda we would all say it was a lemon but even with these problems it is my favorite bike .
95 900 SS SP
Motophoto is offline   Reply With Quote
Old Jul 2nd, 2006, 10:25 pm   #17
rooster747
just bought a 750S
thanks for the heads up! dispite all this, however, i bought a 90' 750S anyways. i walked into the dealership to get a lens for my rear turn signal, and walked out with a Duc.
this is my first Ducati, so im crossing my fingers. i think it might be a fabian cortez replica. but i just dont know, needless to say i have alot of reading up to do.
thanks!
rooster747 is offline   Reply With Quote
Old Nov 12th, 2007, 6:32 pm   #18
Underblog
Underblog's Avatar
Images: 4
750 Sport Newbie Questions
I just took delivery of a 1990 750 Sport, and I have several questions and observations about the bike .
1. I can unlock the seat, but I cannot lift it up to (presumably) get at the tool-box. Is there a trick to this? I am told the owner's manual is in there!
2. The clutch seems sticky; that is with the lever pulled in the bike will still lug around in gear. Adjustment needed, or will a sticky clutch basket do this?
3. Shifting is definitely notchy. From first back to neutral is well nigh impossible, and upshifts are about a 50-50 proposition. Is this a known defect or can I expect things to loosen up?
4. The bike came with Mikuni's installed. Are there any tuning/rebuilding tips?
I am sure there will be more questions, but I appreciate any response to the above.
Eric
Eric W.
03 ST4s ABS
91 851 Superbike
85 F1
Underblog Rides Again
Underblog is offline   Reply With Quote
Old Nov 12th, 2007, 9:22 pm   #19
oalvarez
Lifetime Premium
oalvarez's Avatar
Location: los angeleeeeees, california, land of the ragamuffin
Bravo on the older bike, just love the design, all facets. The moto screams "Ducati Heritage." Borderline garage queen in my eyes. I love it for its looks, just like my 900ss sp.
Enjoy and congrats!
Today
2010 Ducati Multistrada 1200 Sport
2010 Ducati HYM 1100 EVO SP
2009 Aprilia SXV 550
Before today: '10 Aprilia RSV4 Factory, '07 Multistrada 1100s, '09 BMW R1200GS, '09 Monster 1100s, '03 999R, 09' GT1000, '08 HyperS, '08 848, '07 1098,'95 900ss/sp, '92 907ie, '07 Husky SM610
oalvarez is online now   Reply With Quote
Old Nov 12th, 2007, 9:38 pm   #20
TonyTuzz
TonyTuzz's Avatar
Images: 1
Ha! I traded my '90 Sport for a '92 851 back in the day.
Congrats on a neat bike.
It sounds like some clutch actuation issues- I'd start with a good bleeding, making sure all the master cylinder, slave, etc are working right. Mine was notchy under the best circumstances- Mobil1 oil seemed to help shifting a lot.
Also, I tried an aftermarket slave cylinder and the ratio was too low- it didn't push the pressure plate our far enough to work properly. Someone might have tried this on yours, as the stock pull is pretty, ah, manly.
IIRC, the seat either slides back or flips up sideways- not a normal seat removal.
The Mikunis are probably off of a later 750. A good reliable choice. The Weber that came on the bike can be made to work, but tuning either is a black art.
TonyTuzz is offline   Reply With Quote
Forum Jump
Analysis of Ducati 2005 Earnings Results Quantum11 Ducati Motorcycle Chat 52 Apr 9th, 2007 11:53 am
Notes from a Ducati Demo Ride (long) YellowDuck Ducati Motorcycle Chat 3 May 3rd, 2006 5:03 pm
Ducati Sport Classic kits? dmsuchy Sport Classic 8 Apr 28th, 2006 2:21 pm
Ducati Announces SS1000 Race-Only Model Rainman Ducati Motorcycle Chat 3 Feb 5th, 2006 6:17 am
Kawasaki ForumDucati ForumHarley DavidsonYamaha R1BMW S1000RR Forum
Vulcan Forums Ducati MonsterV-Rod Forum Yamaha R6 Kawasaki Z1000
Kawasaki ZX Forum Honda 600RR Harley ForumYZF-R6 ForumSportbike Forum
Kawasaki ZX-10RHonda 1000RRSuzuki SVYamaha FZ8Can Am Spyder
Kawasaki KLR 650Honda RC51Suzuki V-StromStar Motorcycles Aprilia Forum
Kawasaki VersysHonda FurySuzuki GSXR Triumph ForumKTM Forum
Kawasaki EX-500Honda GoldwingGSX-R ForumTriumph 675Victory Forums
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
