BikeBanditMcCoyMotorsportsMotorcycle.comFast Bikes USARiders Discount
Go Back   Ducati.ms - The Ultimate Ducati Forum > Ducati Motorcycle Forums > Supersport
British Motorcycle Gear
Thread Tools Display Modes
Old Dec 7th, 2008, 8:49 pm   #1
rwantin
rwantin's Avatar
Images: 17
New Clutch Slave - Bleed
Okay, so I replaced my old clutch slave with an Oberon on my '92 900SS. I've bled slaves on other bikes before, so I'm not a complete neophyte, and figuring no big deal. Of course, now I'm here. I think this bike laughs at me when I close the garage door.
I followed the instructions that came with the slave - seemed reasonable (squeeze multiple times, open bleeder, close, release lever, repeat). I've done it, say, a hundred times now. I am getting absolutely nothing at the lever.
I've got a hand pump as well. I can't seem to diminish the fluid at the clutch master cylinder either (squeezed or unsqueezed). Nothing is pulling through. I can hear slight whisps of noise at the master cylinder, and at times, air appears to be coming out at the bleeder, but again, nothing. I've tried a few different things, but nothing.
These are very simple principles on how this works, so here I am confused. Is the clutch master cylinder bad? It's the original. It worked fine before, but maybe it's packed it in?
As per usual, any thoughts, insights, tips or tricks welcome. This is the last thing I have to do, and then ready to finally ride the damn thing again.
Thank you (in advance).
Robert
"There's no mini-bar in this room, pal. We're looking for salvation through austerity."
1992 900SS
2007 Bonneville T100
rwantin is offline   Reply With Quote
Old Dec 7th, 2008, 9:19 pm   #2
beekeeper
beekeeper's Avatar
Clutch bleed
Go here, it explains what you need to do.
http://www.ducatisuite.com/clutch.html
Jeff
beekeeper is offline   Reply With Quote
Old Dec 7th, 2008, 9:40 pm   #3
rwantin
rwantin's Avatar
Images: 17
Jeff
Oh man. And I've gone there for nearly everything else <smacking self in head>. Perhaps senility is coming a bit early for me.
Thank you sir.
Robert
1992 900SS
Old Dec 8th, 2008, 12:28 am   #4
markg
markg's Avatar
clutch bleed
I stumbled on the reverse bleed idea after I went through a pint and a half of fluid trying to use conventional bleeding to get the air out. If one is simply replacing fluid, you can cycle it through without the reverse bleed but only if you are VERY carefull not to introduce air into the system, which with the coffin reservoirs is a bit of a challenge.
A thread diversion...I'm having the heads and forks on my SS re-built, and can not wait to get it back. I'm having serious SS withdrawals without it. Getting .95 springs in the front.
Guides were shot, and it needed 1 valve. I knew the guides were tired and rode it about 500 miles longer than I should have, so it needed an exhaust valve.
MarkG
1992 Ducati 900ss
2002 BMW R1150R
1978 BMW R100RS
1970 Triumph Bonneville
1996 Ducati 955SP
markg is offline   Reply With Quote
Old Dec 12th, 2008, 11:01 am   #5
Michael Lee
Michael Lee's Avatar
Talking Old Country Trick!!
I've always used a small pump oil can with 4" nozzle..You just fill it up with Silicon Brake Fluid (make sure can is very clean!!..I keep one for this only)..attach a piece of vacuum line..open slave bleeder a crack and take top off Master Cyl..Start pumping carefully..(put rags or catch can held by wife under master cyl.) one can full should bleed it completely and IT WORKS every time!!
Michael Lee is offline   Reply With Quote
Old Dec 15th, 2008, 9:56 am   #6
rwantin
rwantin's Avatar
Images: 17
Thanks for the ideas guys. This reverse thing sounds intriguing. Did not have a chance this weekend - working too much. Then again, these days, I do not complain about working.
Got the holiday break coming up - and who knows, maybe I can find a wife to hold the can by then.
Robert
1992 900SS
Old Jan 2nd, 2009, 7:25 pm   #7
rwantin
rwantin's Avatar
Images: 17
Hello again...
Per the above, I installed an Oberon clutch slave - I still have the coffin master cylinder. I've done the bleed (actually, I bought the small oil can and the reverse trick seemed to work very well). I bled, and bled, and bled.
So I was ecstatic when I started getting some lever feel, feeling the air had been purged pretty well. Except for one thing - it feels exactly like the brake front brake.
I removed the clutch slave - piston moves back and forth fine (can be pushed in - and moves out with the lever), and the actuation rod is free. Releasing the bleeder screw on the clutch slave relieves the lever pressure.
So I guess I am stuck, or is the clutch? Do I continue to bleed? I did it several times thereafter but the same result. Put the stock clutch slave back on?
As per usual, ANY thoughts, ideas, or guidance are more than greatly appreciated.
Robert
1992 900SS
Old Jan 2nd, 2009, 8:04 pm   #8
Deadguy
Deadguy's Avatar
forget bleeding from the bleeder, i know that sounds weird but just bleed it from the banjo connected to the lever. this crap took me forever and i even broke my stock bleeder and a speedbleeder in the process (btw speedbleeder is a waste).
just pump the lever, put a rag underneath the banjo and crack it open. wash rinse repeat you will be rock solid in no time.
Deadguy is offline   Reply With Quote
Old Jan 2nd, 2009, 8:31 pm   #9
beekeeper
beekeeper's Avatar
Originally Posted by rwantin View Post
Hello again...
Not sure I understand. Is the clutch releasing when you pull it in?
Is it engaging when released?
Are you saying that lever comes to stop before full travel?
You may want to removed the clutch cover to observe the pressure plate movement. With the rear wheel in a stand you should be able to see if clutch is free when pulled in.
Old Jan 2nd, 2009, 9:04 pm   #10
rwantin
rwantin's Avatar
Images: 17
Thanks much - after reading this, I went out to inspect. Just so I understand, there's a screw in the lever (looks like some anti-tampering goo in the screw slot). This is what gets backed out? Again, huge thanks!
Robert
1992 900SS
Forum Jump
Ducati and After-market Clutch Master and Slave Cylinders Shazaam Hall of Wisdom 5 Apr 29th, 2009 4:28 pm
Help! This sound right? Service said clutch was burned out from my MPL slave install akira Superbikes 10 Jul 23rd, 2008 2:29 pm
New Clutch, Decisions, Decisions ... Shazaam Hall of Wisdom 4 Dec 2nd, 2007 6:00 am
Do i need to bleed my clutch? ericeash Superbikes 3 Apr 15th, 2007 8:15 am
What exactly is the typical clutch slave problem nathanTX Ducati Motorcycle Chat 5 Mar 13th, 2006 3:00 pm
Kawasaki ForumDucati ForumHarley DavidsonYamaha R1BMW S1000RR Forum
Vulcan Forums Ducati MonsterV-Rod Forum Yamaha R6 Kawasaki Z1000
Kawasaki ZX Forum Honda 600RR Harley ForumYZF-R6 ForumSportbike Forum
Kawasaki ZX-10RHonda 1000RRSuzuki SVYamaha FZ8Can Am Spyder
Kawasaki KLR 650Honda RC51Suzuki V-StromStar Motorcycles Aprilia Forum
Kawasaki VersysHonda FurySuzuki GSXR Triumph ForumKTM Forum
Kawasaki EX-500Honda GoldwingGSX-R ForumTriumph 675Victory Forums
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
