BikeBanditMcCoyMotorsportsMotorcycle.comFast Bikes USARiders Discount
British Motorcycle Gear
Thread Tools Display Modes
Old Nov 1st, 2008, 10:20 pm   #1
GMP
Thumbs up G2 Ergonomics throttle
I installed the G2 throttle today. Fits perfect in the Ducati throttle housing. I got the one listed for the KTM Super Duke and other twins, but I think any one for a Domino two cable throttle will work. The delrin bushing tube is super smooth. It came with the #400 cam, which is the slowest. Very smooth off idle, and no noticable "hit" from faster ramp up. I didn't measure the cam but I suspect the progression to a faster cable rate is more linear in the last two thirds of travel than the Kyle throttle. Total twist is the same and the throttle bodies do open completely. Next time its off I'll measure it, or I'll get a #200 cam to try. Four different cams are available. Overall I really like it for average street riding.
Glenn
'08 Ducati Hypermotard 1100
'07 GasGas EC250
GMP is offline   Reply With Quote
Old Nov 1st, 2008, 11:46 pm   #2
AXE
AXE's Avatar
I am on it! Thanks for the test and post.
Out!
2008 Ducati Hypermotard
AXE is offline   Reply With Quote
Old Nov 2nd, 2008, 8:42 am   #3
GMP
The grip stop ring on the G2 tube is a few mm farther away from the housing than the OEM tube. A ProGrip gel Superbike grip bottoms out with some overhang on the end of the tube. This was of no concern and everything fit perfect and worked smooth, I had filed the locator off the housing but it would have lined up anyway. If this bothers you you could either trim the stop ring off, or cut the grip end flush with the tube, but its not neccessary.
Service was fast, shipped same day FREE!
Glenn
'07 GasGas EC250
Old Nov 2nd, 2008, 1:11 pm   #4
08hyper
08hyper's Avatar
Question
Is there a "CAM" equal to the stock Hyper tube? TIA Alex
it is what it is, and always will be.......
08hyper is offline   Reply With Quote
Old Nov 2nd, 2008, 1:52 pm   #5
GMP
Yes, or more accurately probably yes, if the OEM Hyper throttle cam is close to that used on a KTM. I suspect they are all the same. #100 is OEM profile(no ramp), #200, #300, #400 (progressively slower first third throttle).
Glenn
'07 GasGas EC250
Old Nov 2nd, 2008, 3:38 pm   #6
08hyper
08hyper's Avatar
Question
How much? and where did you order it? TIA Alex
Old Nov 2nd, 2008, 8:34 pm   #7
couchflyer
couchflyer's Avatar
Images: 35
GMP you purchased this? -
G2 Throttle Cam System for KTM
SKU: tcs_ktm
for KTM 995/990 - 2008 and newer ~ correct?
Thanks
2008 Hypermotard 1100s
1998 916SPS
Sola Gratis
couchflyer is offline   Reply With Quote
Old Nov 2nd, 2008, 9:15 pm   #8
GMP
Yes.
http://g2ergo.com/shop/catalog/G2-Ta...r-KTM-196.html
Specify the delrin bushing tube.
Glenn
'07 GasGas EC250
Forum Jump
Throttle lock and throttle resistance? axismotorrad Sport Classic 16 Feb 26th, 2009 8:37 pm
New '06 ST3 has INSANELY twitchy throttle! SWriverstone Sport Touring 7 Dec 4th, 2007 12:50 am
Throttle Smoothness - Mechanical or Mental? HawkDucati Superbikes 25 Jan 28th, 2007 6:46 pm
Throttle Rocker vs Cramp Buster BlueST2 Ducati Motorcycle Chat 16 Sep 18th, 2006 6:28 pm
Some points on doing a throttle body synch richardtl Supersport 14 May 4th, 2006 12:19 pm
Kawasaki ForumDucati ForumHarley DavidsonYamaha R1BMW S1000RR Forum
Vulcan Forums Ducati MonsterV-Rod Forum Yamaha R6 Kawasaki Z1000
Kawasaki ZX Forum Honda 600RR Harley ForumYZF-R6 ForumSportbike Forum
Kawasaki ZX-10RHonda 1000RRSuzuki SVYamaha FZ8Can Am Spyder
Kawasaki KLR 650Honda RC51Suzuki V-StromStar Motorcycles Aprilia Forum
Kawasaki VersysHonda FurySuzuki GSXR Triumph ForumKTM Forum
Kawasaki EX-500Honda GoldwingGSX-R ForumTriumph 675Victory Forums
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
