» Site Navigation |
» Motorcycle Forums
» Buyers Guide |
» Links |
Sep 6th, 2007, 11:47 am
#1
Moderator
Gettin' More Sound Out Of the Stock GT1000's Pipes.
After vacillating for over a year between keeping the overly quiet stock exhaust system or installing an overly loud (to me) set of Termis on my GT I decided to see what I could do to modify the originals so as to get bit more sound out of them. What I did was simple but amazingly effective. In fact I'm more than a bit surprised by how well it worked.
Understanding that the stock cans consist of a series of chambers I drilled two holes in the rear of each can, one above, one below the exhaust outlet. The holes went through the chrome cover and then through the rearmost chamber which is about 1 1/2 inches further in.
I first created a starter hole with a 5/32" bit and then progressively enlarged it to 5/16th.
I started with one hole and moved ahead progressively after listening to the effect on the bike's voice. Each added hole, and the enlargement thereof, increased the sound level and slightly changed the timbre. Two 5/16 holes in each system created just the sound level I was looking for.
Following the drilling of the baffles I took two additional steps for the sake of appearance: First I smoothed out the holes with a Dremmel tool, then I painted the entire recessed area in the end of the exhaust canister with flat black wood stove paint. This gives the appearance of a single large outlet instead of the small appearing aperture in the stock pipe.
Of course the key question is: How does it sound?
In a few words: Very unique and very good.
The prime difference, apart from the added volume level, is the inclusion of “bark” and added complexity to the exhaust note. If I had to compare the overall sound of the bike at idle to something it’d be a `50s era open-motored V8 hot rod. Very busy, complex, and mechanical. Underway, from the rider's seat, however, it's pure Ducati, with an especially nice growl on over run.
I’m at work now. I can’t wait to get home and start ‘er up. But it will be especially hard not to take her out for a ride if I do. Fun. Fun. Fun!
Cost? Zilch. Except for a couple of dollops of paint which I already had on hand.
Pix will follow.
-don
DUCeditor
Ducatis Unlimited Connection
www.duc.bz
`07 GT1000 "Sommessa Donna" (Quiet Lady)
`93 900SS "La bella Rossa" (The Beautiful Red)
Sep 6th, 2007, 2:55 pm
#2
Yes pics please - a sound clip would be nice too!
Sep 6th, 2007, 3:16 pm
#3
Lifetime Premium
Don,
That was a bold move. What if drilling those holes didn't work out - would it have been Staintunes or Termis???
Sep 6th, 2007, 5:06 pm
#4
Moderator
Originally Posted by egrafx2006
Don,
Perhaps, but since I planned on doing the job step by step I figured going back and sealing the at-first very small holes would be relatively easy. A spot of weld. A metal ring. Anything would do. And since I wanted to paint the area flat black regardless I was really being less bold than you might imagine. Besides... "Nothing ventured, nothing gained." Eh?
Now I've got to say something else... If any of you kind readers looked heavenward when you read my description of the sound and muttered "Bull Sh_t!!!" I won't blame you a bit. Even to me what I wrote (though an honest appraisal of my thoughts yesterday afternoon) seemed like it had to be over the top. But as I said I would, my first activity upon getting home was to open the bike shed and let her rip. Folks this was no BS nor was it hyperbole. And what I did can be duplicated by anyone of you. The steps are there and they are simple. (Just make sure you have a powerful, preferably variable speed, drill and good quality bits)
In a word: WOW!
OK, is this "as good" as a set of Termis? No. Termis add power and lower weight. My alteration just enhances (!) the sound. But it does sound great without being "too" loud. (It is louder than I originally expected it to be, but oh, so nice!)  And it cost next to nothing. That's cool!
Pics will follow as soon as I have hardened the 2nd coat of woodstove paint (which requires heat) and then buffed the transition between the chrome and the paint line so that it (hopefully) fades in.
A sound file would be nice. I have a digital recorder and a couple of large diaphram mikes in my studio so this is possible. But ideally I'd need an assistant so I could do a run by a various speeds. Too, without good speakers and a sub the real power of the sound won't be there. I also have a sound level meter, btw, so if someone could provide me with detail of the standard measuring procedure I could also (again, if I had an assistant to help me) provide a db level.
Cheers all!
-don (An extra happy camper)
DUCeditor
www.duc.bz
Sep 6th, 2007, 6:49 pm
#5
see, i did it on my v-star once and i will never do it again. i just hated the sound..after i got open pipes it was much more twin sounding.
Sep 6th, 2007, 7:02 pm
#6
Originally Posted by DUCeditor
...so if someone could provide me with detail of the standard measuring procedure I could also (again, if I had an assistant to help me) provide a db level...
Don, I measured sound at 1 meter (~1 yard) straight out sideways (perpendicular) from the exit of the exhaust. This is an industrial standard. My Termi's without baffles clocked in at 105 dB at 4500 rpm in neutral.
Jeff
Red GT1000: - Termis (sans baffles), DP chrome bar-end mirrors, Clay Carrier fork protectors, Motovation frame & fork sliders, Dietrich's gauge brackets (these rock), Front turn indicator spacers removed, 1.0 kg/mm fork springs, Fork Oil: 7 wt.comp, 5 wt.reb, DP grab rail / luggage rack & bag, 15/44 F/R Sprockets, Gold DID Chain, Chain guard removed (to show off the chain)...
Sep 6th, 2007, 8:22 pm
#7
Great work Don,
Please try to post a sound file. This is exactly what I had planned on trying with my GT this winter.
Cant wait to hear it,
Weaz
Sep 6th, 2007, 8:47 pm
#8
Awaiting the fotos...
and sample clip.
50%
Sep 6th, 2007, 9:16 pm
#9
DUCeditor:
Nice to hear about this mod as I too think the 'uncapped' Termis are a bit loud, not to mention 1400$ installed.
Do these 'extra exhaust outlets' make any difference in the way your bike runs?
Aware of any warranty issues here?
Ride safe!!!
SJ
Sep 6th, 2007, 9:56 pm
#10
+1 on the pics
| Thread Tools |
| Display Modes |
Linear Mode
