MotorbikeUniverseMcCoyMotorsportsMotorcycle.com Classifieds!Riders Discount
Cycle Gear
Thread Tools Display Modes
Old Feb 28th, 2006, 3:55 pm   #1
nathanTX
nathanTX's Avatar
Images: 5
Speedo Cable - crap!
Today's weather in TX is what all motorcycle enthusiasts live for. High 70s and sunny with a mild South breeze. So I decide to spend the afternoon in the twisties. Don't even have to come up with an excuse to play hooky since I don't have a job right at the moment. But I get about 10 miles from home and my speedometer dies. WTF? Turns out when I changed tires recently the speedo sensor shifted and caused a kink in the speedo cable which finally wore through from pulling tight over and over as the forks went up and down. So, it was straight home for me so I could investigate and make sure I wasn't doing any further damage to the front wheel/fender/speedo .
Big props to AMS Ducati, though. They had the part in stock for $32 and are just dropping it in the mail since they're about a 45min drive. Should have it fixed before the weekend. Plus he told me exactly what I did wrong on the spot. He said that when you tighten up the wheel, the speedo sensor has a tendency to rotate clockwise, pulling the cable tight. Says just about everyone does it once.
*** LESSON TO BE LEARNED: When reinstalling the front wheel (on 748/916/996 at least) make sure that the speedo sensor unit stays pointing up rather than back as you tighten everything up, otherwise the cable won't have enough slack to accomodate turning and suspension travel.
So, who else has done this?? (please? so I don't feel so stupid)
Nathan
2001 Ducati 996
"The proper function of man is to live, not to exist. I shall not waste my days in trying to prolong them. I shall use my time." - Jack London
nathanTX is offline   Reply With Quote
Old Feb 28th, 2006, 4:01 pm   #2
kingsnake1650
kingsnake1650's Avatar
Mine broke up and the top by the guage cluster.Not sure why though.... that is a good tip about putting it all together though
Grow up and quit your whining. To the rest of you: Grow a set! Learn to tell the Whiners to SHUT UP!
kingsnake1650 is offline   Reply With Quote
Old Feb 28th, 2006, 4:35 pm   #3
grendels_arm
Sam I am Green Eggs and Ham
grendels_arm's Avatar
Images: 9
Wow this is good to know. Now I know why the Haynes manual or Ducati Service manual said to keep the tab on the speedo sensor pressed against the white stop tab of the fork ring while tightening. I was wondering why they were pointing that out. I thought it was because if it moved or something you couldn't turn it back once the wheel was on. But then I saw you could so wondered why. Hmmm. My track bike doesn't have a speedo cable.
Sam
NESBA #96 (I)
1998 Aprilia RS250
1998 Honda RS125
grendels_arm is offline   Reply With Quote
Old Mar 1st, 2006, 3:10 pm   #4
xr1owner
xr1owner's Avatar
I broke mine after 50 miles of putting on my PVM wheels.. ooopppssss... .
xr1owner is offline   Reply With Quote
Old Mar 1st, 2006, 3:52 pm   #5
stiver2
The same happened to me. I had the tyres changed at a tyre fitting place and 38 miles later snap at the bottom of the cable, you're not alone!
stiver2 is offline   Reply With Quote
Old Mar 1st, 2006, 6:47 pm   #6
cheech
cheech's Avatar
Images: 8
One more thing too, don't bind your forks by overtightening the axle nut. I would usually tighten it up nice and snug, spin the wheel for smoothness, untighten nut, slide out the axle slightly with rubber mallet and reseat it back in, and then retighten to specs. This insures that it doesn't create too much pressure between the bearings/speedo when you're forcing the axle through the forks and bearings.
cheech is offline   Reply With Quote
Forum Jump
Rerouting 749/999 throttle cable montducati Superbikes 5 Feb 8th, 2006 9:51 pm
Kawasaki ForumDucati ForumHarley DavidsonYamaha R1BMW S1000RR Forum
Vulcan Forums Ducati MonsterV-Rod Forum Yamaha R6 Kawasaki Z1000
Kawasaki ZX Forum Honda 600RR Harley ForumYZF-R6 ForumSportbike Forum
Kawasaki ZX-10RHonda 1000RRSuzuki SVYamaha FZ8Can Am Spyder
Kawasaki KLR 650Honda RC51Suzuki V-StromStar Motorcycles Aprilia Forum
Kawasaki VersysHonda FurySuzuki GSXR Triumph ForumKTM Forum
Kawasaki EX-500Honda GoldwingGSX-R ForumTriumph 675Victory Forums
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
