Siemens fueling check-in - Ducati.ms - The Ultimate Ducati Forum
Old Nov 15th, 2010, 3:06 pm   #1 (permalink)
Question Siemens fueling check-in
Does anyone have any further information from the horse's mouth of the people working toward a functional map/device/whatever for the Siemens fuel injected models? The low RPM stumbling together with the gunshot-like popping on decel after installing the LV cat eliminator is starting to get kinda old
jryden is offline   Reply With Quote
Old Nov 15th, 2010, 3:48 pm   #2 (permalink)
el tardo's Avatar
memjet is a quick fixfor your 796.not as good as a full race ecu but will help with fueling and get rid of your issues. come up to calabasas and ride mine and you can see.
mike
2010 black 796
dont make me badge you!!
el tardo is online now   Reply With Quote
Old Nov 15th, 2010, 4:34 pm   #3 (permalink)
Mike: I'll take your word for it. Where did you end up placing the unit on the bike? Did you get the extension cable as well?
mike
Old Nov 15th, 2010, 6:13 pm   #4 (permalink)
el tardo's Avatar
i got it from mr mike after he got a full race ecu
i put it on my bike about a week after buying it
i dont think it has the longer cable all is right under air box and easy to get to
2010 black 796
Old Nov 15th, 2010, 7:26 pm   #5 (permalink)
i just finished re-flashing my ECU and getting the TPS reset at the local dealer (about 20 bucks and 10 minutes). For $500 i bought a protune and re-mapped the ECU to very similar (if not exact) mapping. I also installed a cat eliminator and some leo vince slips ons along with a TPO beast intake.
Initially the bike has a lot of decel popping, but after having the dealer adjust the bleeder screws and do a TPS reset, it ran much better! Very little pop on decel and it seems to be getting better as the ECU adjusts its parameters.
HankinSD is offline   Reply With Quote
Old Nov 15th, 2010, 8:00 pm   #6 (permalink)
el tardo's Avatar
hank when you say bleeder screws-what are they? what do they control? air intake on idle? not trying to sound stupid but that term is meant for carbs
2010 black 796
Old Nov 15th, 2010, 8:39 pm   #7 (permalink)
sorry, ha ha, definitely should have been specific on that one. The screws i am talking about are on the sides of the throttle bodies. They have a minor affect on idle speed but are mostly used to adjust the leanness or richness of the bike. Furthermore, they help with balancing the throttles.
Old Nov 16th, 2010, 12:38 am   #8 (permalink)
Similar to what?
Old Nov 16th, 2010, 6:24 pm   #9 (permalink)
johnnie27's Avatar
Similar to what?
do you think he means the DP ECU settings? as you cannot program the pro-tune yourself from what i am told? they (dealer) load a map that you ask them too, and app for the 2010 there are only 2 maps to pick from
Termi Install and Siemens TPS - Heads up SpeeLaT Monster 10 Jun 5th, 2011 8:40 pm
Siemens ECU update Mr Mike HyperMotard 0 Jul 26th, 2010 4:19 pm
2010 Evo Model, with siemens ECU-Termis 07 to 09 sinex HyperMotard 1 Jan 31st, 2010 12:58 pm
