Oil Temp Gone Crazy!!! - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGear
Old Nov 13th, 2010, 2:42 am   #1 (permalink)
Mmmmm Vanilla!
WakeDude's Avatar
So I was riding along this afternoon, doing some exploring. It was in the mid 70's but there was some traffic. Oil temp climbed to 224F last time I looked down. So another 15 minutes and I get to the curvy stuff. I toggle through and check my temp...171F....184F....201F....195F.....etc. It just kept jumping around. So I pulled over to look for any signs of danger. None we seen. I get to the gas station maybe 30 minutes later, fill up and when I go to check the temp, all is fine, no jumping.
Alright so when I was in the curvy stuff I was just cruising, not pushing the bike at all. I knew the temp was less than in traffic because we were moving, and so I had little concern for the temp jumps.
So my question is..... Have you guys had any experience with this "jumping oil temperature" reading? Thanks.
-Alex
-Alex
2008 Hypermotard 1100 S "Lola" - (SOLD)
2006 Multistrada 1000S DS "Duckie"
Follow me on Descubre-La-Vida Blog
Follow me on Facebook
Follow me on SPOT
WakeDude is offline   Reply With Quote
Old Nov 13th, 2010, 2:48 am   #2 (permalink)
el tardo's Avatar
if the 1100 is the same as the 796 the temp sensor is in the rear head not the oil it self.could be a loose connection or short or something more serious.do you have a temp gun to verify temps?
2010 black 796
dont make me badge you!!
el tardo is online now   Reply With Quote
Old Nov 13th, 2010, 8:04 am   #3 (permalink)
freezer16801's Avatar
I believe the sensor wire is attached to the right side of the oil cooler on the top. I just had mine off yesterday for some valve maitenance to get the cooler out of the way. It is a female solderless wire connector similar to what you would use on speaker wire in your car. The connector slides over a copper button on the top right of the cooler. The setup isn't ideal. I would look there first.
08 Ducati HM
03 Yamaha R6 track bike
02 Suzuki TL1000-R RIP baby
Old Nov 14th, 2010, 2:12 am   #4 (permalink)
Mmmmm Vanilla!
WakeDude's Avatar
Thank you guys, will check those.
-Alex
-Alex
Follow me on SPOT
Am I crazy!!! HELP!!! RedMamba Superbikes 25 Jul 9th, 2010 11:45 am
Air Temp vs. Engine Temp BPA5150 Monster 4 Jul 10th, 2009 3:15 pm
Am I Crazy? Gav Monster 0 Apr 7th, 2009 6:16 pm
Temps... oil temp VS Coolant temp Geof3 Superbikes 6 Oct 26th, 2008 12:13 am
Track Temp vs Tire Temp lastblast Superbikes 6 Dec 31st, 2006 6:24 pm
