DP flywheel - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGear
Old Nov 11th, 2010, 9:24 pm   #1 (permalink)
Question DP flywheel
Hi do you know if the DP Flywheel for the HM is Aluminium or steeel ?
Motorcycle Maniac
10 Ducati Streetfighter
08 Ducati Hypermotard
08 Aprilia SXV-550
10 Gas Gas TXT280 Pro
06 Kawasaki KXF-450
96 Beta Thecno
95 Beta Thecno
shwantz34 is offline   Reply With Quote
Old Nov 11th, 2010, 10:11 pm   #2 (permalink)
08hyper's Avatar
aluminum
Old Nov 13th, 2010, 5:11 pm   #3 (permalink)
HUMM!
Any bad feed back about Aluminium flywheel ?
I Have heard some bad things about them taking some loose
and making bid damage. I would like to find a stock steel that its been lightened.I would like to keep mine as spare if i don't like the feeling of the lighter one.
Originally Posted by 08hyper View Post
aluminum
Motorcycle Maniac
08 Aprilia SXV-550
06 Kawasaki KXF-450
96 Beta Thecno
95 Beta Thecno
Old Nov 13th, 2010, 5:55 pm   #4 (permalink)
el tardo's Avatar
or get a 848 one that is already lightened
Originally Posted by shwantz34 View Post
HUMM!
2010 black 796
dont make me badge you!!
el tardo is online now   Reply With Quote
Old Nov 13th, 2010, 6:10 pm   #5 (permalink)
freezer16801's Avatar
are you saying the stock 848 wheel is lighter than the hyper one?
08 Ducati HM
03 Yamaha R6 track bike
02 Suzuki TL1000-R RIP baby
Old Nov 13th, 2010, 6:16 pm   #6 (permalink)
el tardo's Avatar
copied from the ducshop--
For all 3 phase Ducati\'s, 1999 and up: From 5 lbs. to 1 lb. 12 ozs. 748,996/998/999/1000SS/ST4/1098/Hypermotard ect...the 848 and 1098R are already 2 lbs. 3ozs. so not as necessary.
2010 black 796
Old Nov 13th, 2010, 6:23 pm   #7 (permalink)
have you heard if one has been mounted on a hyper?
08 Ducati HM
Old Nov 13th, 2010, 6:27 pm   #8 (permalink)
el tardo's Avatar
from ducshop
QUOTE=Ducshop;767613]My quote:
"Here is a comparison of the 3 phaze flywheels:
Top left is on 1999 thru 2006's (748/999,ST4ect..)5 lbs.
Top right is 1098's, Hyper's ect.. 4 lbs.10 ozs.
Bottom right is on 848's and 1098R's 2 lbs. 3 ozs.
Bottom left is after we machine/bal. them 1 lb. 12ozs"
The Hypers get a lighter one than the older bikes.
IMO, I think they are using the 848 flywheel now because it is an easy way to lower the weight of the bike for advertising, is fewer part numbers to inventory and it doesn't cause a big change. [/QUOTE]
i also have one and going to install it right after thanksgiving,waiting on friends track day to be over and waiting on the deep impact 30mm socket
2010 black 796
Old Nov 13th, 2010, 10:11 pm   #9 (permalink)
laslunas's Avatar
is replacing the flywheel a minor job?
laslunas is offline   Reply With Quote
Old Nov 14th, 2010, 12:59 am   #10 (permalink)
08hyper's Avatar
Its a medium job.......unless your name is Decreasing Dave, then it is a major one Aloha Alex
FS: 996 Flywheel Fishmonger Parts and Accessories 1 Jul 23rd, 2010 11:32 am
999 Flywheel HELP! 998Robbie Superbikes 1 Dec 30th, 2009 12:59 am
748 flywheel jimmy98 Superbikes 17 Apr 8th, 2009 4:27 pm
Flywheel Nut... dirkwrong Supersport 18 Oct 18th, 2008 10:33 pm
What does a Flywheel do? ChasCrewChief Superbikes 37 Jun 13th, 2007 10:26 am
