I have a big winter project for my HM.
I decide to try to do it step by step ( as much as i can ) just to have an idea of what works and what doesn't.
First Mods about 8weeks ago i put a Fat Duc on my 100% stock HM except for a 14th front spocket.I put the fat Duc, adjust it to a 13to1 A/F ratio then adjust the air bleeder and finished with a very smooth running, silky smooth idle with a very smooth and instant response.No more bug, no more hesitation.Even more surprising, it was now like 1 gear better everywhere.( pops wheely in 2nd as easy as it was in first before,same things in third vs 2nd).So i decide to put back the 15 tooth gear and it pulls enought to pulll wheely easy in 3rd gear. Best $80.00 ever.
Mods 2:
Sc project 2-2 exhaust
I have looking around for a long time for an exhaust for my HM, and decide to go with this one because it was a real dual exhaust with bigger diameter for a more easy flowing exhaust, and because my target at the end of the project is to find some more rev up top without loosing to much down low.Also i like the look of it,and like the feedback i receive for the sound.I install the pipe yesterday.Very good quality,very well made. install have been ultra easy for all the pipping,very precise fitting and easy to figure out even without any instruction.The only problem that i find was to fit the bracket for the baffle.
Since i haven't modify the air box, and have a Fatduc on it, i decide to start it up and see how it works.
it start instantly, and it sound wonderful. Pretty loud thought,but its ok for me.Without any other adjustement out of the box, it have a very good idle, response is very good, and it seems to run good everywhere.
Next test my wheely dyno tell me that its even easier to pull up, lot more torquey ( you can let it go down and put it back up without touching the ground) can we say mega torque
Its seems to pull a bit more on top too, but i'm pretty sure that when i will have open the air box it will give me a lot more.
Note all the test since the Fat Duke have been done in a very miserable temp beetween 5 to 10 degree C ( f... cold here already)
Next step : Duke Shop stack kit, DP cam kit with the DP ECU and Pistal 11.25 to 1 Pistons. I will also put a MBP shim kit and change the Belt at the same times.
Last thing,s that i have to decide is : Do i give my heads to Guy Martin for a mega head work ( bigger valve, 5 angle job, repostioning of the intake and remodeling of the port ).
I'll keep you inform of my progress !
